AC question. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-03-2013, 12:36 PM Thread Starter
BSkopnik's Avatar
AC question.
So I had to drop the truck off at dealership only shop could get into. Anyways. Ac clutch is shot. Now got two options. Just replace clutch or bite bullet spend 300 more to replace compressor. It's an 02 all orig. thoughts?
Sent from AutoGuide.com App
02 F350 CC LB 4x4 Lariat
Done: K&N CIA, Torklift Camper tie down system, Firestone Ride Rite Air Suspension(Dual guage control, w/ reservoir tank), Autometer 3 Pillar guage(Boost,EGT,Tranny Temp), Vision Type 81 19.5" w/ Goodyear G622 RSD 245/70r19.5 LRG, 03-07 power/heat/light mirror conversion, Sinister Coolant Filter kit.
ToDo: Powerslot Cryo rotors, Hawke SD pads, 6.0L Tranny Cooler, Oil Temp/Pressure, Fuel Pressure and Diff Temp guages.
BSkopnik is offline
post #2 of 6 Old 07-03-2013, 12:40 PM
i vote for windows down. It isn't like it gets that hot where you live.
zillafreak is offline
post #3 of 6 Old 07-03-2013, 12:42 PM Thread Starter
BSkopnik's Avatar
Lol fair enough. Not me I'm concerned. We head stateside for camping often. The little guy bakes in the heat. And I rather like things working right if I need them. I just don't have time right now to do work myself or I'd put it off a bit. Bit leaving in 2 days to head south leaves me little time to work with.
BSkopnik is offline
post #4 of 6 Old 07-03-2013, 12:47 PM
I would say replace it all, and with the compressor, you will need to recharge the system.
post #5 of 6 Old 07-03-2013, 04:39 PM
Do a search online... there is a lot of talk about a quick, cheap fix to get the clutch to engage by removing a shim to adjust the air gap.
If you actually need a new clutch, then I vote for a full replacement also. It sure would suck to fix the clutch only to find out that your compressor gets a leak in the near future.
I just replaced mine, along with a new drier/accumulator and an orifice tube. Both of those items will be necessary in order to qualify for the compressor warranty, plus they are both smart things to do at the same time.
I used all Motorcraft parts, and the prices were reasonable.
2000 F350 4X4 CCSB w/ 7.3 and 4R100
PIS 175/80, Adrenaline HPOP, 4" Exhaust, 6637 Filter, CCV Mod, Leveled Front, 315/75/16 Goodyear Duratracs
Devil Car is offline
post #6 of 6 Old 07-03-2013, 06:38 PM Thread Starter
BSkopnik's Avatar
I did look at the shim fix. Was all just worn too good. Ended up cheaping out though, just doing the clutch. Already regret it but that's my problem now. Haha oh well.
Edit:The boy stole the phone and hit send. Haha
BSkopnik is offline
