Delete the EBP Sensor? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-02-2013, 09:26 AM Thread Starter
Colin7.3's Avatar
Amid my searching I found a ebp sensor delete. It plugs into the plug and sends Thar signal that all is good in the world for that sensor.
Then I can just plug the hole in the exhaust and call it a day.
Is this a good idea or a bad one? Would I see any performance issues?
I ask cause I need a new sensor and this would be a cheap alt.
Thanks!
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #2 of 2 Old 07-03-2013, 11:23 AM
timmyboy76's Avatar
had mine plugged at the manifold, and npt capped at the sensor, ziptying it up. Didnt seem to do anything vs re-installing a new sensor and tube. It will however come into play if/when you decide to get tunes. Reason why i re-installed mine.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
