Installing Cab lights tomorrow ADVICE - Ford Powerstroke Diesel Forum
Old 04-05-2008, 01:07 PM
Send a message via AIM to mattypsd
i am going to install recon dodge cab lights ( older sytle )
on my 02 F350
any advice..
i am going to follow a mix of directions.
motoman's madness
a few others
anyone here mounted these lights up before
please chime in and give me some advice
and things to watch for
and anyone out there with instructions and pictures
please send them to me. im looking for more detailed instructions
thanks
Old 04-05-2008, 01:10 PM
Rob Rob is offline
i installed the OEM lights on my old F-250, just make sure you have the proper spacing, measure 2 or 3 times the drill. i would also pre build the harness if you dont have one already, it will make the wiring alot easier.
Old 04-06-2008, 06:34 AM
Infidel
1) Measure,
2) Measure again,
3) Repeat steps 1 & 2
The hardest part for me was making that first hole. Take your time, lay everything out and it should turn out fine.
Good luck,
Craig
Old 04-06-2008, 11:24 AM
Measure measure measure....
Also, you might want to make a template. A little tough with the curve of the roof, but it makes it easier to try different spacings and also to get the measurements and holes lined up exactly right.
i am assuming your lights come with a rubber bas plate? use a ring of gasket maker anyway to ensure they don't leak, you can never be too careful with the roof!
Old 04-07-2008, 11:22 AM
International Threat
I have a writeup on this in the tech files...
Cab Lights + Install/Pictures/DIY
