temps too high??? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-01-2013, 12:22 PM Thread Starter
j350rx's Avatar
temps too high???
so cruising at 70 on the freeway with a dirt bike and and camping stuff loaded in the bed my trans temp was staying about 193 and my engine oil temp was 212 and egt was about 950. it was 100 degrees outside. superchips was set to fuel saver mode. too high on any or still safe? thanks J
02 f350 4dr 4x4 lariat
ATS compressor housing
x wheel compressor wheel
s&b intake
foil delete
ebpv unplugged
red waistgate hose plugged
4"mbpt exhaust turbo back
edge cts monitor
superchips programmer on performance setting
6" procomp lift
37" toyo mts
j350rx is offline
post #2 of 8 Old 07-01-2013, 12:32 PM
Joel's Avatar
Quoted: 10 Post(s)
Still totally safe
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 8 Old 07-01-2013, 01:31 PM
blue99stroker's Avatar
Quoted: 246 Post(s)
your good
might install a tranny cooler to keep the trans temp down.
i need to get a new tranny cooler as well.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #4 of 8 Old 07-01-2013, 02:33 PM Thread Starter
j350rx's Avatar
ok thanks guys! im looking for a used cooler now but none at the yard yet. when climbing hills i saw up to 1550. let out a lil and got down to the 1300's. how long can i keep the temps up high to climb a hill? and what breaks if it stays too hot too long? turbo? thanks J
s&b intake
foil delete
ebpv unplugged
edge cts monitor
6" procomp lift
37" toyo mts
j350rx is offline
post #5 of 8 Old 07-01-2013, 02:40 PM
Joel's Avatar
Quoted: 10 Post(s)
I wouldn't want to stay at 1500 long at all.
If you gear down and run the hill in 3rd at a higher RPM the egts should drop. Or look into getting a larger exhaust housing for your turbo.
I have the 1.15 van housing and I can't get the egt past 1250 if you paid me to. Where as the stock turbo would get as hot as I let it very quicky
Joel is offline
post #6 of 8 Old 07-01-2013, 05:37 PM
There are a couple of 6.0l coolers in the fs section on this forum and others. Might be more than you want to pay but they are there
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #7 of 8 Old 07-02-2013, 02:32 PM Thread Starter
j350rx's Avatar
so do i need the whole van turbo or just the exhaust housing and i can use my ww and
ats compressor housing? J
s&b intake
foil delete
ebpv unplugged
edge cts monitor
6" procomp lift
37" toyo mts
j350rx is offline
post #8 of 8 Old 07-02-2013, 05:19 PM
Joel's Avatar
Quoted: 10 Post(s)
You can buy just the housing. I bet riffraff or dieselsite woulsd have what you need.
Joel is offline
