Another tranny cooler question - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-01-2013, 06:39 AM Thread Starter
jdereu's Avatar
I know what you guys are going to say, buy a 6.0 one and be done with it well i dont have that kind of funding now are rarely tow really heavy.. with that said I found one on riffraff's website and i know Clay is a good guy and wouldnt lead me wrong. I was wondering if anyone else runs this one Riffraff Diesel: Derale 20,500 GVW Transmission Oil Cooler.. If so how is it? What kind of temp change will I be looking at?
Thanks
2000 Ford F-250, Crew Cab Long Bed 4x4, Automatic Transmission, Ts 6 Position, 4" MBRP Exhaust, DIY Intake, Pillar Guages, CCV Mod
jdereu is offline
post #2 of 12 Old 07-01-2013, 10:54 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Thanks
If your on a budget a tru-cool max 47391 is a good upgrade similar in size to a V-10 trans cooler. Rated for up to 40k GVW. Costs about 150 or so but worth it.
A 20k tube and fin cooler doesn't seem worth it to me, stacked plate and fin coolers (like your factory cooler, a v-10 cooler, tru-cool and the 6.0 coolers) are much more efficient and in many cases the preferred option for most OEM cooling applications.
Just a heads up rock auto has new 6.0 coolers for under $300.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #3 of 12 Old 07-01-2013, 11:37 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
That cooler is way to small and inefficient your stock one is better. Get a 26 or 31 row 6.0 cooler.
CT Performance, Inc. is offline
post #4 of 12 Old 07-01-2013, 11:59 AM Thread Starter
jdereu's Avatar
I would run it inline with the stock one if that makes any difference
jdereu is offline
post #5 of 12 Old 07-01-2013, 01:32 PM
blue99stroker's Avatar
Quoted: 244 Post(s)
trucool from dieselsite is only like 130 bucks.
40,000 GVW
6.0 is better but tru cool is a little cheaper
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #6 of 12 Old 07-01-2013, 01:36 PM
Quoted: 17 Post(s)
Depending on how the hose is routed you could cause too much restriction doing that. No sense saving 30-40 bucks on a cooler to have possibly higher temps or an improperly lubbed trans. I would just save up for a cooler that is at least an upgrade.
post #7 of 12 Old 07-01-2013, 01:41 PM
layson's Avatar
Quoted: 79 Post(s)
Go rummage around the nearest junkyard. I bought mine for 30 bucks...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #8 of 12 Old 07-01-2013, 06:58 PM
chrispaine's Avatar
40,000 GVW
The tru cool is an add-on unit not a replacement correct?
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #9 of 12 Old 07-01-2013, 09:12 PM
As Layson said.
You can find a good used 6.0l cooler for less. Even spending 150 on a used 6.0l cooler.
I hardly tow but my tranny is always happier with the 6.0l cooler. Its direct bolt in minus the tubing and you will never have to worry about it again. Some things you do not want to skimp on and this is definitely one of those items
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #10 of 12 Old 07-01-2013, 10:49 PM
Gaius's Avatar
Quoted: 40 Post(s)
My truck has been fine with a 24kish GVWR Tru-Cool, ran about $90. I only tow my Jeep though, but temps MAYBE get up to 160. I think I've seen it at 180 once.
I'll need to get the 40k one to get it behind the bumper though for the intercooler upgrade.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
