Random no start w/ clicking - replaced lots of items already - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-29-2013, 10:39 AM Thread Starter
Eco Taxi's Avatar
Ok so it seems like once a month ill jump in my truck and once I turn the key you just hear a click sound but the engine doesn't turn over - just the click sound.
I can simply start the truck using a screw driver and hitting the terminals on starter solenoid that's on the fender and with the key on the truck starts
But I've replaced (not all related to this problem) the starter solenoid, starter, both batteries, ICP, IPR, CPS, alternator, water pump, thermostat, gpr, all glow plugs, EOT sensor, blower motor resistor, ..... Then there's misc replaced items like brakes, calipers, abs sensor, brake lines etc.
All fluids recently changed, checked my uvch and it ohms correctly
So due to the random nature of this no start I'm thinking it might be a grounding issue for the starter solenoid or starter .... Anyone have a diagram on this electrical system
Or anyone else have thoughts .... It's weird because it happens once every three or four weeks and I just turn the key and then the click sound so I bypass it with the solenoid
This has been an on-going problem since I bought the truck before I changed or modded anything
Kyle
2001 F350 Chassis Cab 4x4 DRW Flatbed 130k miles+
Quad Gauge Pillar - Aeroforce Interceptor & Glowshift Series 7 EGT, Boost, Trans Temp
Foil Delete | Marinco Mod | High Torque 4kw Starter | Door Seal Mod | AIH Delete | Coolant Filter & 203* Thermostat w/ Billet Aluminum Housing | Hutch Mod | RiffRaff Fpx, Hpx, boots | WW2 | Deleted ebpv
“The good thing about science is that it's true whether or not you believe in it.” ― Neil deGrasse Tyson
Eco Taxi is offline
post #2 of 8 Old 06-29-2013, 08:42 PM
mcyrana's Avatar
if your hearing that click the solenoid/starter circuit is getting its power and ground so thats good.
that last time i had this problem it was my starter because crap from my valley drained into my bell housing and that stuff went in my starter, replaced the starter and havent had a problem since
Originally Posted by dentexpowerstroke View Post
I've already explained that to him multiple times tho and he doesn't understand... Im about to bust out some crayons and draw it for him.
6637 Filter, Warn locking Hubs, Recon LED Cablights, Leveled 2", 8" CAT Stack, 35" Goodyear Duratracs, High pressure oil crossover tube
mcyrana is offline
post #3 of 8 Old 06-29-2013, 11:59 PM
had the EXACT same problem. fixed it last week, it was my starter. but it worked fine for almost two years but every month or so i would get the click and no start, i would just keep hittin the key and it would finally start.
its hard to diagnose things when they happen so randomly like that, it sucked.
wait so whats the difference between turning the key and using the screwdriver? if it was the starter or starter solonoid then it shouldnt work either way right? i would trace everything from the key to the solonoid where you start it with a screwdriver, if the system works from that spot then the problem has to be upstream right?
_________________________________________
02 f350, AFE stage 2 intake, wicked wheel, edge
evolution, performance authority trans, 10" lift 38's
with 4:56's, C2 gauges, 4" turbo back AERO muffler
TD444EVER is offline
post #4 of 8 Old 06-30-2013, 05:17 PM Thread Starter
Eco Taxi's Avatar
Well I have to have the key turned to the on position - if I crank it over you hear the click
Then I go under the hood and have the screw driver touch two terminals on the starter solenoid and it starts
So I think it's simply grounding or wiring....
I don't think it's the starter because when it cranks over by itself it starts up instantly and when I use the screw driver I bypass the terminals it also starts instantly
Kyle
Eco Taxi is offline
post #5 of 8 Old 06-30-2013, 05:19 PM Thread Starter
Eco Taxi's Avatar
But just like you two guys said - you replaced the starter and its fine and that's what most people say when I've researched this problem
Kyle
Eco Taxi is offline
post #6 of 8 Old 07-01-2013, 06:04 AM Thread Starter
Eco Taxi's Avatar
I've also read where a possible problem lies with a manual level position switch
4R100 Manual Lever Position Switch
Anyone know anything about this?
Kyle
Eco Taxi is offline
post #7 of 8 Old 07-01-2013, 08:10 AM
Joel's Avatar
Quoted: 10 Post(s)
I don't think this is your issue, but double check that the bolts holding the starter on to the block are good and tight.
Slightly loosened up on me once cause an intermittent bad ground and no start issue. Best part is, the fix was free.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #8 of 8 Old 07-01-2013, 11:03 AM
Quickhorse's Avatar
yeah, had the same problem. Starter was only a couple years old and was the nippon denso high torque starter. Had a short somewhere in the starter so I got another one and boom it was back to normal. Clean the bolts off real good and clean the mating surfaces off from the starter face and transmission. SOS pad and brake clean. Also see if you have a tear in the power or ground wires of the starter to solenoid.
2008 F350 CCSB FX4 Amsoil fluids, S&B intake, 5" exhaust, Egr delete, Boss V plow, Mega Duty Title mod.
Quickhorse is offline
