motor randomly shuts off - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-29-2013, 05:37 AM Thread Starter
the stroke's Avatar
I have a 01 with 220***.Stage one single shots 6 position programmer. the truck runs great 99.9 percent of time. But when I go to this one bar 30mins away. The motor randomly shuts off as I'm coming up to the stop sign in front of the place no lights nothing everything stays on except for the motor. I can put it in park fire right back up the last night it did it four times within a hundred feet and then when I left the bar and took the same path nothing happened. anybody got any ideas besides not going that bar anymore lol.
the stroke is offline
post #2 of 6 Old 06-29-2013, 07:02 AM
russtwentyfour's Avatar
Do a search there's a post somewhere about a guy who was having the same problem. His truck would die everyday at the same spot in the road, I may be wrong but i think it turned out to be the tuner or idm. I'm sure some else remembers the post I'm talking about?
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #3 of 6 Old 06-29-2013, 07:58 AM
Quoted: 818 Post(s)
Sounds like CPS is wigging out.
Corey@CNCFAB is offline
post #4 of 6 Old 06-30-2013, 03:36 PM Thread Starter
the stroke's Avatar
What's the CPS? control positioning sensor? And why would that only happen there.
post #5 of 6 Old 06-30-2013, 03:45 PM
Quoted: 818 Post(s)
No. Crank Position Sensor. They are a prone problem. Most people keep a spare in their glovebox at all times along with a socket for it.
I meant "Cranking"
post #6 of 6 Old 06-30-2013, 03:45 PM
aussie=effie
bob harris's Avatar
shuts off
CPS is CAMSHAFT POSITION SENSOR. A problem little bugger and needs to be replaced every 100,000 kms. Down front end of motor, easy to replace so I am told ??
bob harris is offline
