monitor question - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-28-2013, 07:43 PM Thread Starter
monitor question
I had to put a new transmission in my 02 7.3 last week. I am looking in to buy a monitor to watch transmission temp and a few other things. Was looking at the Edge Insight CTS monitor. What will it monitor on the 02 and does anyone with the same year have one and if so how do you like it? I also looked at the bully dog and scan gague along with the edge insight cs. I don't want to be sinking my money into something that want work. Not sure if this makes a difference but I tow a 322qbs 5th wheel by keystone. I'm guessing around 12000 lbs loaded. What all should I be monitoring while towing down the road. Was towing this last week in the mountains when transmission went out. Had 140,000 miles on it. Any help would be greatly appreciated. I am slow learning alot from this site and am thankful to be able to a member here.
scrnt is offline
post #2 of 18 Old 06-29-2013, 02:37 AM
Macon's Avatar
I have the Insight CTS with the EGT probe. Works great. It monitors everything the PCM sees, plus the EGT. I use all 8 gauges that I can, still wanting a couple more.
The two biggest things to watch are tranny temp and EGT, especially when towing. The dummy gauge on the dash won't tell you the tranny is over heating until after you burn it up.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 18 Old 06-29-2013, 09:03 AM
Quoted: 728 Post(s)
Dp tuner Infinity. Plus you get AE similar software. Its a bit pricey though.
Corey@CNCFAB is online now
post #4 of 18 Old 06-30-2013, 12:11 PM Thread Starter
thanks for the info probably going with the cts just waiting on a little ot to pay for it.
scrnt is offline
post #5 of 18 Old 06-30-2013, 05:42 PM
timmyboy76's Avatar
upgrade the tiny 7.3 trans cooler to the 6.0 cooler.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 18 Old 07-05-2013, 04:47 PM Thread Starter
ordered the cts last night. When they changed out the tranny the put a new cooler in.
scrnt is offline
post #7 of 18 Old 07-10-2013, 07:03 PM Thread Starter
Got my insight cts in today and hooked up to truck really simple. Set up my gauges the way I like. Noticed that the boost gauge is showing 0 all the time did i do something wrong or does that not work on the 02 f250? Thanks
scrnt is offline
post #8 of 18 Old 07-10-2013, 07:19 PM
79 toy's Avatar
Is it showing 0 while your driving?
79 toy is offline
post #9 of 18 Old 07-11-2013, 06:12 PM Thread Starter
drove it to work today it is working. I went wopt and only saw 16 psi of about mabe 1/10 mile. When I did that my oil temp went to about 197 198 degrees is this normal temp? I have heard that tranny temp and oil temp should be within 15 20 degrees of each other but tranny temp was only around 140. Just had the coolant flushed and refilled monday. Just got my egt probe in mail today plain on install sat.
scrnt is offline
post #10 of 18 Old 07-11-2013, 06:34 PM
AnthonyU's Avatar
Quoted: 8 Post(s)
First of all if you got the CTS hooked up under your dash then your only seeing what your computer is showing. If you want to be more precise then you need to add on or stack the probes/sensors to read directly from the (ex) turbo,tranny,egt, etc you get the drift. Now if you truck is modded you should put a AIH delete kit and monitor turbo boost there I also recommend a boost fooler as well if you don't already have one. If your truck is stock then you will only read turbo boost up to like 20 psi then you will de-fuel you will see this on the CTS display. I have one and it work great but the critical things I monitor I bought additional sensors. Good luck and enjoy
AnthonyU is offline
