2000 f250 7.3 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-28-2013, 04:46 PM Thread Starter
2000 f250 7.3
My truck was running fine, stopped at the grocery store and when I got back in the truck would not start. Turn the key and nothing, had to jump the solenoid for it to start. any ideas on what my problem is?
mdk1955 is offline
post #2 of 5 Old 06-28-2013, 05:48 PM
Colin7.3's Avatar
Did you jump the solenoid on the fender well?
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #3 of 5 Old 06-28-2013, 07:21 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Starter is fried! Had the same thing happen to an IDI only i was laying in a mud hole trying to get it started. Take a hammer and tap the starter a couple times see if that helps? Solenoid ontop of the starter may have crapped out! Thats what they are known for
Sent from AutoGuide.com App
2000-7.3L is offline
post #4 of 5 Old 06-29-2013, 02:32 AM
chrispaine's Avatar
Sounds like when my fuel heater fried... there is a fuse under the hood that needs to be replaced (fuse #30) and you have to unplug the connector to the fuel filter bowl.
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #5 of 5 Old 06-29-2013, 05:00 AM
goats's Avatar
Quoted: 2 Post(s)
If that was the case ,the truck would not have started at all. Since that fuse shares with the pcm as well.
goats is offline
