running rough-- help, wife is mad - Ford Powerstroke Diesel Forum
post #1 of 55 Old 06-28-2013, 01:27 PM Thread Starter
dieselcrawler's Avatar
Quoted: 23 Post(s)
It's time to post about my latest problem...
Wife's daily driver. 2000 Excursion Limited, 264K miles. Had 243K when we got it a little less than 2 years ago. Has run fine since then, stock aside from Edge Evolution programmer that was on it when we got it, and I did my favorite mod, the DIY intake/6637 air filter. 20K miles no issues, untill now. Batteries are about a year and a half old, replaced the alternator (6 mos ago).
Starts but runs rough, won't take fuel, won't rev up. A week or so a go, it did this, Edge went nuts, reset to stock BS, (even though it was already set to stock) no start, theift mode, etc. Was cranking slow, so charged the batteriies. Started fine after that. unpluged Edge completely (was only using it for gauges anyway).
Could weak batteries cause these issues? Have enough juice to start but not enough to power IDM and run it properly? Perhaps a weak alternator? I'm at a loss... plugged Edge back in to use it to read codes and now it won't even work.
Now, today, same thing. Will start, romping rough idle, won't rev/take fuel. Have drained water drain, no change.
What about CPS? I've heard they will just not start at all if it's CPS, not the type issues I'm seeing. I can rob parts from my yellow dually of the same year if it's an IDM issue, or anything else for that matter. What I don't have is any way to check the codes.
Please help me out here... wife is asking me why I can't fix it, thought that's why we bought a high mileage truck because I knew everything about them, etc. What I do know is how to ask questions from people who do know... help!!!!
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #2 of 55 Old 06-28-2013, 05:04 PM
Joel's Avatar
Quoted: 10 Post(s)
If you're able to swap parts without too much trouble, try the fuel pump. To me it sounds like it could be that.
Then try ICP, IPR until one works
Are you sure the UVCH is hooked up properly? They tend to rattle loose and make it run like butt or not at all.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 55 Old 06-28-2013, 07:34 PM
Do you have ae? Its going into limp mode. I would say something related to injectors. As you know it could be a number of things.
Uvch, injectors, hpop related, idm (but highly doubt).
You could try a different cps but I seriously doubt that is the problem.
Ohm out the uvch from the outside. Thats where I would start, otherwise I say it might be an injector but not certain
Its not the batteries imo. I lost my alt and had no juice left in the batteries. Got it jumped and raced to napa. Lost all lights, instruments, power, etc and it still drove fine.
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
post #4 of 55 Old 06-28-2013, 07:48 PM Thread Starter
Quoted: 23 Post(s)
I do not have or have access to AutoEnginuity or any type of scanner...
I DO have my yellow dually sitting by the barn not being used and can swap parts to trouble shoot the issues.
So where are these parts you speak of located physicly, to swap out?
Could it really just be the fuel pump, as mentioned? I think I can hear it running but that's no garrentee pressure is high enough.
Greg
Semper Paratus
post #5 of 55 Old 06-28-2013, 08:03 PM
I would ohm out the valve cover connector first. Ill see if I can find the instructions.
For now you can put the gnd to the center pin and pos to the ea of the 2 pins on ea side of the center pin. Those go to the injectors. The outter 4 pins are for the glow plugs.
If you do not get anything on the injector pins, the uvch either came loose or has issues.
I really do not think its a fuel issue but ive been wrong before.
You can always run a hose off thefuel bowl drain tube into a can. Start the truck and open the drain. If it has good flow then its not a fuel problem.
Try this
In the bottom video on the link down below, ken is checking Glow plug resistance. Use the center terminal c, and measure resistance between c and Each i to check injectors. Measure resistance of the glow plugs between g and battery ground. Values are down at the bottom.
Terminal positions=G G I I C I I G G
G=Glow Plug
I=Injector +
C=Injector -
Ohm Glow plugs between "G" and Battery Negative post. Should be between 0.1 and 2.0 Ohms
Ohm Injectors Between "C" and "I" should be < 5 ohms
https://sites.google.com/site/woodnt...ow-plug-system
INFRNL is offline
post #6 of 55 Old 06-28-2013, 08:15 PM
Quoted: 728 Post(s)
Sounds like u have multiple issues. The romp seems like it might be uvch. Check each plug for tightness to each valve cover.
The no rev/fuel may be a fuse. I can't remember which number it is but it supplies power to your TPS.
When is the last time you changed the fuel filter?
Does the fuel pump make an obvious smooth running sound when you turn the key on but not start?
To kinda check fuel pressure since you don't have a gauge, put a catch pan under ur truck, turn the key forward and then open the pet**** valve on the back of the fuel bowl. Watch it spray out underneath by the oil pan. That will let you know in a round about way if there is decent pressure to at least rev the engine with no load.
Corey@CNCFAB is online now
post #7 of 55 Old 06-28-2013, 08:25 PM
I had the same symptoms as the op and it ended up being a bad injector. When you get romps and no/poor pedal response it is the truck going into limp mode to prevent further damage.
Mine had romps for the first time ever, idled rough, had a hard time running, no pedal response, kept dying, etc.
It will be hard for him without ae or something similar. At least he has another truck to borrow parts from if need be
INFRNL is offline
post #8 of 55 Old 06-28-2013, 08:35 PM
Quoted: 728 Post(s)
I agree but not always a bad injector will cause romp. Sometimes its timing, partial cps, or even tunes. Mine did it when I had my PHP chip. Gearhead chip, no more romp. But mine only did it when slowing down from highway speeds.
Also agree it'll be a bit more difficult w/o AE.
Hopefully we can get you going OP.
BTW mods, really Petco*ck is flagged. That's what its called.
post #9 of 55 Old 06-28-2013, 08:56 PM Thread Starter
Quoted: 23 Post(s)
Fuel filter changed about 3k miles ago.
What gets me is that it did this a week or so ago then was fine. Started it again then was ok after a good battery charge. Started doing it again shortly after that but quit after I turned it off and started it back up. Next time I started it- today- it's doing it again.
Seems random and spiratic. Batteries charging now just to make sure.
Find it hard to believe it's an injector... been running too good otherwise. Would one or more just totally die instantly? Yellow truck has one that 'sticks' untill it gets warmed up but once warm it runs good.
Guess UVC harness is first in line to check... fuel pump output...
Greg
Semper Paratus
post #10 of 55 Old 06-28-2013, 09:13 PM
russtwentyfour's Avatar
Fuel level? Could be sucking air either in tank or at one of the quick connects. Just a thought
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
