Had my truck at ford and either my idm or my injector wiring harness needs replaced. Don't want to pat ford prices. any recommendations an getting a reman idm. Riffraff has the harness for $40.
Swamps Diesel sells an high voltage high frequency IDM for $275. By the looks of your mods,it would be perfect on your truck. I can tell a difference on my truck,better throttle response,but with aftermarket performance injectors I think you'll have even better results and its cheaper than a Ford IDM.
The Bean's IDM $150 price is only for you to send yours in to be modified then they send it back. And it has to be working. They don't accept nonworking IDM's. I do believe.
To the op, you can ohm out the uvch from the outside plugs. This will tell you right away if you have an uvch issue. Only takes about 5 mins. Maybe the uvch worked loose, do the 50c mod.
I still doubt its the idm. If you lived in colo, I could let you try my stock spare so you dont waste your money.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
