99 2WD 7.3 4" lift? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-28-2013, 06:01 AM Thread Starter
Quoted: 8 Post(s)
99 2WD 7.3 4" lift?
To start out my truck has a FabTech 6" left kit on it now.
I looking for a way to get the front down about 2" or so to 3.5" to 4" of lift. Been looking for springs for ever, I go to SEMA every year for work so I have time to ask all the Manufactures and no one seems to have ever made a 4" kit for 2WD.
Will 4WD springs mount in a 2WD?
Can I put 6" Gas springs in the front and will they live with the extra weight?
Open for ideas. I have thought about cutting the front springs - the issue is bending them after cutting them so they will lock and mount on the truck after.
ToyMan is offline
post #2 of 5 Old 06-28-2013, 11:21 PM
alaskan155's Avatar
Quoted: 66 Post(s)
Products > FORD 2WD > F250/F350 1999-04 > 4" Systems > Basic Systems
cross reference this kit with the 6 inch kit and see what you need to replace, might be able to get away with just ordering the 4" springs
2002 F250 7.3/JW Tow master 4r100 212k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles, Redhead steering box
alaskan155 is offline
post #3 of 5 Old 06-29-2013, 06:58 AM Thread Starter
Quoted: 8 Post(s)
Alaskan thanks for the link - This is the kit they made for gas powered trucks - they say the springs will not hold up to the 7.3's weight. Not sure why they never did the same for Diesel's?
ToyMan is offline
post #4 of 5 Old 03-31-2014, 03:54 AM
thepaynetrain's Avatar
Ok guys. I have a 99 f350 extended cab short bed with a 7.3. I bout it with stock. I put a t's 6 pos, Spectre intake and custom straight pipe. I want to put a lift on the old girl but I'm having trouble figuring out what to put on her. My buddy from michigan suggested hockey pucks under the leaf springs on the axel. ( I know that sounds effing retarded) I am on the budget range for around 250 at most. I have 12 inch long u bolt in the front so plenty of room for more leafs but I wanted to see what y'all would suggest. I would start a new thread but I am fresh meat and don't have the ability to start one yet. Help me out guys cus I really hat the nose dive look and I don't wanna put hokey pucks under my leafs hahahaha. My gf thinks the truck is already sexy as hell but an added lift will make her marry me hahaha.... Hopefully
thepaynetrain is offline
post #5 of 5 Old 03-31-2014, 06:10 AM
timmyboy76's Avatar
you could block the front or atleast, try a new set of excursion leafs. maybe that'll level her out.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
