Cleaning my engine compartment????? - Ford Powerstroke Diesel Forum
Old 04-01-2008, 02:47 PM
Question Cleaning my engine compartment?????
I want to clean up the engine and my engine compartment. Is it safe to spray it out with water or pressure washer??? What do I need to be careful with??? Any suggestions on cleaners or degreasers????
Old 04-01-2008, 02:50 PM
Desert Shield/Storm Vet
Any degreaser will work. I use the Purple something from Nappa. I don't recommend high pressure just use the hose and rinse the engine down avoiding the alternator. I usually start it up right away to blow any water that might have gotten into the alternator.
Old 04-01-2008, 02:51 PM
you can also put a plastic bag over the alternator as well
Old 04-01-2008, 02:55 PM
obviously avoid any electronics as much as possible and they also reccomend the motor being cool. I use gunk Engine degreaser, pretty good stuff
Old 04-01-2008, 03:05 PM
awsome! thanks guys
Old 04-01-2008, 03:09 PM
duct tape & zip ties
I use Engine Brite from Seal Gunk, it comes in a spray can you can get it at pretty much every part store. Then you follow the directions I always use a pressure washer to rinse my engine.
Old 04-01-2008, 03:11 PM
Lets get some pics of clean engines
Old 04-01-2008, 03:16 PM
Old 04-01-2008, 03:19 PM
you suck man, I dont think I could ever get mine that clean, let alone stay that way hahaha
Old 04-01-2008, 03:28 PM
Hahaha mine needs a bath again its been a long winter
