7.3 Missing, Fails Cyl Contribution 1 and 3 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-27-2013, 09:24 AM Thread Starter
rolsmojave3's Avatar
Truck is missing, failing the cylinder contribution test on 1 and 3. Passes Buzz test. Shop Replaced UVCH, engine harness, IDM. When I first starting working on truck, It would fail 1, 3 and 5. Now we're down to 1 and 3. UVCH looks good, Ohms out OK. Injectors have oil coming from the spills.
I believe this to be fuel related, is there a check or restriction on the front of the head, causing these 2 cyl to not get fuel? Fuel pressure is holding at 60psi with pump running. Any thoughts, Thanks!
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #2 of 5 Old 06-27-2013, 03:17 PM
blue99stroker's Avatar
Quoted: 272 Post(s)
did you try replacing the cps?
thats like 25 bucks.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 5 Old 06-27-2013, 04:02 PM
jesilvas's Avatar
Quoted: 2 Post(s)
This is an OBS right?
Either way, I'd replace CPS too. Could be because of this - Black, Grey, & Dark Blue Cam Position Sensor Perdels Test - Diesel Forum - TheDieselStop.com
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 5 Old 06-27-2013, 08:40 PM Thread Starter
No it's a Superduty. Turns out, through very thought out process, it was air in the passenger fuel rail. Removed the front plug, bled system, truck runs great, customer very happy!
post #5 of 5 Old 06-27-2013, 08:41 PM Thread Starter
Previous shop replaced #3 injector, UVCH, and IDM.
