Gold Flakes in Rear End Gear Oil - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-26-2013, 10:44 AM Thread Starter
Jamessims's Avatar
Any ideas? after finding this I am 80% sure this is where my vibration is coming from... going to pull the cover tonight and inspect it.
2000 2wd Ford Excursion 7.3
Jamessims is offline
post #2 of 11 Old 06-26-2013, 11:24 AM Thread Starter
Jamessims's Avatar
so if its a bad deal what year rear with leafs should i stick under the X ~?
post #3 of 11 Old 06-26-2013, 11:31 AM
blue99stroker's Avatar
Quoted: 289 Post(s)
i had a little gold flakes when i changed mine but everthing looked good.
changed the gear oil and checked again about 5k miles and no flakes.
what symptoms are you experiencing?
if its a slip on take off id say put some grease on the slipjoint. its a 5-10 min job.
ct performance can help you with the springs. contact them.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is online now
post #4 of 11 Old 06-26-2013, 12:21 PM Thread Starter
Jamessims's Avatar
Vibrating down the road going 65 plus the faster you go the worse it gets
Sent from AutoGuide.com App
post #5 of 11 Old 06-26-2013, 12:46 PM
Quoted: 289 Post(s)
id say u-joints are shot.
but it could be coming from the rear end too.
post #6 of 11 Old 06-26-2013, 05:44 PM
Quoted: 17 Post(s)
I'd say u-joints as well or possibly the drive shaft is out of balance. I'd do ujoints first though.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #7 of 11 Old 06-26-2013, 05:45 PM
Quoted: 17 Post(s)
Btw did you find the leprechauns pot of gold when you opened to inspect? Lol
TBJK is offline
post #8 of 11 Old 06-26-2013, 07:30 PM Thread Starter
Jamessims's Avatar
Yelp sure did changed the gear oil out tonight will report back in the morning... I checked the ujoints and they look new along with the driveshaft it all says spicer on everything even the yoke... Unless that is stock? I ran the car up on a jack under the pumpkin and ran it up to 50plus mph and hear a groan noise coming from the rear... Driveshaft does not look out of balance and all the weights where still on it when I ran it up from 50-75mph I have video but don't know how to post it
post #9 of 11 Old 06-27-2013, 12:50 PM Thread Starter
Jamessims's Avatar
ok changed out the fluid and looked at the cover and it had a coating of thick gear oil sludge kinda made me think it had not been changed out in a long time.....cleaned it up and put near gear oil in but went with 85-140 cuz they didnt have 75 so we will see how the drive goes today!
post #10 of 11 Old 06-27-2013, 02:09 PM
Quoted: 289 Post(s)
hopefully some fresh oil will get you along for a little bit.
