  #11 (permalink)
Old 12-02-2005, 02:38 PM
wesjones wesjones is offline
i do mine every 4 or 5k, i dont think changing it at 3 will hurt anything but your wallet maybe, obviously the issue is changing oil later rather than sooner
  #12 (permalink)
Old 12-03-2005, 05:02 PM
turbotime turbotime is offline
Send a message via MSN to turbotime Send a message via Skype™ to turbotime
10,000+
No doubt about it, I am good to go for 10,000+miles on mine. I use the AmsOil, which I would just swear by. It is 15W40 Marine/Diesel. I also have installed a dual oil filter system and use the AmsOil filters. Change every other time.
  #13 (permalink)
Old 02-01-2006, 05:38 PM
toothless toothless is offline
Every 5000 miles. No issues.
  #14 (permalink)
Old 02-02-2006, 08:38 PM
mschn99 mschn99 is offline
i reccomend every 4k....this gives you a little leighway......if your thinkin about it and have time...it may get done below 4k....and if not....it still gives you time to do it before 5k if you go over.....i would not reccomend going over 5k.....this would be like your kidneys not puting good filtered blood in your body....it is what keeps your motor alive and is the single most important service..........Marc
  #15 (permalink)
Old 02-03-2006, 05:01 PM
danman danman is offline
oil change
I get my oil changed at the local ford dealer every 5000 kilometers. not sure what that would be in miles. they use 10w30 oil year round here in canada.
  #16 (permalink)
Old 02-03-2006, 05:14 PM
10-30 may be a little thin for summer....but if its workin for ya, i wouldnt mess with it......
  #17 (permalink)
Old 02-03-2006, 06:17 PM
overl0rd overl0rd is offline
Send a message via ICQ to overl0rd Send a message via AIM to overl0rd
I go roughly 3k, sometimes I just can't do it then and there so I'll end up a couple hundred miles over. I run 15W40 Rotella T and Motorcraft filter. I change the fuel filter every other oil change. I'm at 3500 on this oil, haven't had time to change it yet between working on the bikes and the house and everything else that doesn't include chnging the oil, so I've been driving the Tbird instead. Of course with the work I've put into the bird I could have changed the oil in the truck a couple of times by now.
Edit: Done now, figured I should do it before the snow hits here.
  #18 (permalink)
Old 02-03-2006, 07:40 PM
stomper2 stomper2 is offline
7,500 and like Gear Jammer said, fuel every other.
  #19 (permalink)
Old 02-03-2006, 09:01 PM
this may be overkill....but ill bet your motor has less problems and lasts longer than the others.....over the long haul anyways.......kinda funny how "going overboard" pays off in the end......Marc
  #20 (permalink)
Old 02-03-2006, 09:37 PM
Yeah I keep telling myself its overkill, but at the same time I'm pretty obsessive compulsive about maintenance on it. I have a habit of fixing stuff before it breaks/wears out.
