Off road fuel in the ole 7.3???? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-25-2013, 06:50 PM Thread Starter
carazola's Avatar
Pros or cons of doing so??
carazola is offline
post #2 of 13 Old 06-25-2013, 06:53 PM
goats's Avatar
Quoted: 2 Post(s)
It's the same fuel,but it has a red dye. you will get a big fine if caught running on the street.
goats is offline
post #3 of 13 Old 06-25-2013, 07:18 PM Thread Starter
carazola's Avatar
That's dumb, guess I assumed there was more of a difference
carazola is offline
post #4 of 13 Old 06-25-2013, 08:43 PM
russtwentyfour's Avatar
What about high sulfer diesel? The place our company refuels our big rigs has a high sulfer diesel pump. Pros cons?
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #5 of 13 Old 06-25-2013, 09:02 PM
Chug-a-lug!!!
colberjs's Avatar
Quoted: 11 Post(s)
Which part are you saying us dumb?
Jesse
2011 F-250 Fx4 CrewCab Short Bed
Bone Stock............Or Is It?
colberjs is offline
post #6 of 13 Old 06-26-2013, 03:02 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
Offroad fuel is dirtier plus its 10k a gallon fine(and they go by the size of your tank)
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #7 of 13 Old 06-26-2013, 03:28 AM
Colin7.3's Avatar
Wrong on the dirty. Correct on the fine
Offroad diesel now is also ULSD because the new farm equipment require it with the new emission systems ( yes tractors, generators, bulldozers, all have a dpf on them).
The only difference is there is no road tax on the fuel. And that they dye it red to be able to tell if people put it in a road vehicle that drives on legal highways and interstates.
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #8 of 13 Old 06-26-2013, 09:10 AM
Quoted: 16 Post(s)
Off road seems to have more trash in it
post #9 of 13 Old 06-26-2013, 11:12 AM
ThomasvillePavers's Avatar
Depending on where you get the off road I have seen debris in it, most small fuel sites treat those tanks and such with less respect and that would be the only reason it might be "dirty" but the fuel itself is the same. In my younger years getting caught didn't have the same meaning as it does for me now and there is NO way I would risk it today! DOT is becoming stricter and enforcing these types of laws much more now and I cannot afford the fine so I wouldn't suggest risking it... However I know the 7.3 can handle the fuel fine as long as you keep on the filters as you should anyways...
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #10 of 13 Old 06-26-2013, 09:28 PM
Off rd fuel where I live is not much cheaper than reg diesel; I think maybe 20cents cheaper per gal.
If someone is too cheap to pay the few $ difference, then they shouldnt own a diesel to begin with.
Our company doesnt run dyed diesel anymore cause in the long run its more expensive. I do not recall the whole process.
Also a word of advice, if you have any equipment that you run dyed diesel in, be careful if you road it on public streets cause they will stop you and check the fuel. You can get fined for dyed diesel in equipment on public rds
03 F350 7.3L Auto CC LB Dually 410's (LS Rear)315's
PHP/Beans tuned, 250/100 FF inj's, BTS Tranny, Strictly Diesel complete fuel system w/RR & FB Delete, Pius LASB from Irate, Swamps hvhf IDM
Autometer Nexus Guages (TT,FP,BP,EGT), 4"MBRP, DieselSite Coolant filtration system/billet housing/HP X-Over line, Baldwin PA2818(6637) RR Boots, 26 row 6.0 Tranny & PS Cooler, LarryB's Denso Starter
INFRNL is offline
