EBPV Removal - Ford Powerstroke Diesel Forum
post #1 of 26 Old 06-25-2013, 04:53 PM Thread Starter
usteffenhagen's Avatar
EBPV Removal
Hey yall I was thinking about removing my EBPV. Will it affect/change/ or make anything run better or cahnge the sound without it? I notice a decent amount of folks remove it and just wanted to check and see if its even worth it
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #2 of 26 Old 06-25-2013, 09:40 PM
timmyboy76's Avatar
living where i'm at, it doesnt even come into play.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 26 Old 06-26-2013, 05:19 PM Thread Starter
How so?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 26 Old 06-26-2013, 06:16 PM
kclough's Avatar
I live in central Illinois and I removed mine during winter because mine was leaking and sticking shut. I bought an aftermarket pedestal for an turbo upgrade in the future and also it won't leak again. And deleting it does not do anything except have the high whistle while warming up
kclough is offline
post #5 of 26 Old 06-26-2013, 06:35 PM Thread Starter
ok thanks a bunch
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #6 of 26 Old 06-26-2013, 06:44 PM
kclough's Avatar
I'm sorry i made a mistake the difference in deleting it is that it does not have the high whistle while warming up like it does with the ebpv
kclough is offline
post #7 of 26 Old 06-26-2013, 07:48 PM Thread Starter
Oh ok gotcha. I was just thinking about removing it because 1. I notice other guys do it and 2. I just don't really like the hissing sound the truck makes when its cold outsite and the lack of power until she warms up. It was about 30* outside one morning and i had to listen to it all the way to work and I was worried something was wrong until I posted on the org about it. Until now, the only diesels I drive were the trucks at work so I never really dealt with it since they all have a CAT C-12 or C-15 engines
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #8 of 26 Old 06-26-2013, 10:43 PM
Quoted: 782 Post(s)
Deleting? Are you just unplugging it? I recommend removing the butterfly in the exhaust housing flange. Use a 1/2" pipe tap to put threads in (the hole is perfect size already no drilling) and use Allen head plugs.
Corey@CNCFAB is offline
post #9 of 26 Old 06-26-2013, 11:00 PM Thread Starter
Ok now if I do that, what exactly will that do?
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #10 of 26 Old 06-26-2013, 11:06 PM
Quoted: 782 Post(s)
Help exhaust flow. Especially at times when your foot is heavy. Less back pressure on turbo and egt's
