how long is too long for a sitting transmision? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-25-2013, 09:30 AM Thread Starter
kblv247's Avatar
I have a 4r100 that was removed from a wrecked truck back in 2007. the tranny had 9000 miles on it after a complete rebuild. it has been sitting on my shop floor ever since. My current tranny is making high temps and the tourqe coverter is not locking up between shifts unless i let off the gas.
kblv247 is offline
post #2 of 11 Old 06-25-2013, 10:52 AM
layson's Avatar
Quoted: 82 Post(s)
I wouldn't think there would be any problems with it...
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #3 of 11 Old 06-26-2013, 09:43 AM Thread Starter
kblv247's Avatar
im just hesitant because of the amount of work to install the tranny. i think im going to go for it though.
kblv247 is offline
post #4 of 11 Old 06-26-2013, 09:50 AM
ZMANN's Avatar
Quoted: 1564 Post(s)
i would install
or maybe change any easy external seals ?
We Miss you Ronnie
ZMANN is offline
post #5 of 11 Old 06-26-2013, 10:05 AM Thread Starter
kblv247's Avatar
ya im going to go for it
kblv247 is offline
post #6 of 11 Old 06-26-2013, 10:45 AM
Quoted: 17 Post(s)
I'd say go for it but change the input & output seals before you do all that work to find out the seals are dry rotted.
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #7 of 11 Old 06-26-2013, 11:20 AM
Quoted: 364 Post(s)
Feedback Score: 5 reviews
I had a tranny laying for 1.5 years as a spare...... Installed it a few weeks ago. Runs perfect!
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #8 of 11 Old 06-26-2013, 11:39 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
just depends on if it was out of the weather and full of fluid.
me and my uncle pull apart 50 year old Volkswagen transmissions all the time and the ones that sit outside are almost worthless and ones that are covered and full of gear oil are pristine.
so id say if its been kept somewhere inside you shouldn't have a peroblem
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #9 of 11 Old 06-26-2013, 12:26 PM Thread Starter
kblv247's Avatar
ya its been in the barn and is full of fluid.
kblv247 is offline
post #10 of 11 Old 06-26-2013, 12:47 PM
Quoted: 258 Post(s)
ok then you should be golden.
id say put some new atf in there when you get it all hooked up and just check the seals before you put it in.
