TC Lock Tech Question - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-30-2008, 08:54 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
I don't expect many people to know this one, hopefully though someone on here has a bit of experience and knowledge about the electrical system on these trucks.
Its my understanding that when you do the manual TC lockup mod, in order to make the OD light not flash, you have to fool the PCM into thinking it still has control of the TC. You do that by feeding it a resisted 12v signal.
Now my question. Since that works for tricking the PCM when manually locking it, does the same thing apply for a manual unlock? If i wire it so it sends the same resisted 12v when manually unlocked as when it is manually locked, will it keep the OD light from flashing? Or will I fry my PCM? Or will it just do nothing and flash anyway?
Can anybody help me on this one?
BPS President
2000 F-250, forged rods, 38r turbo, BTS trans, hutch mod, TW tuning and Bad Night Special 50 horse Caterpillar injectors
Originally Posted by alberta 7.3 View Post
Yeah, I'd probably feel a bit drained after firing twice in rapid succession.
Jake is offline
post #2 of 17 Old 03-30-2008, 09:20 PM
Good question, I don't have an answer. But I am curious on why you would want to manually unlock the TC?
99.5 F250
Airaid intake
4" Turbo back, straight
6" lift with 37" BFGs
Boost, Trans, EGT Gauges
Tirepaq
AIH delete
DP Tuner 40/80/120/140 with Gauge Switch
6.0 Intercooler
Foil Delete
Whicked Wheel
Billet T/C
Brand new Tranny
Zoodad Mod
6.0 trans cooler with 2 fan controlled coolers.
KCM S.S. HPX Line
Snow Performance stage 3 meth kit
Sinac is offline
post #3 of 17 Old 03-30-2008, 09:23 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
For sled pulling. I've heard that you can do better if you keep the TC from locking. I think it was CSIPSD that told me that he has his set up so he can manually lock or unlock the TC. He said his OD light flashes though, im trying to figure out how to make it not flash.
BPS President
Jake is offline
post #4 of 17 Old 03-30-2008, 09:25 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
nope, it was strokin_early_99 that told me about it.
BPS President
Jake is offline
post #5 of 17 Old 03-30-2008, 09:52 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Common, someone's gotta know.
BPS President
Jake is offline
post #6 of 17 Old 03-30-2008, 09:57 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 114 Post(s)
I think you could add another relay to provide the PCM with a resistive load, and break the connection with the TC. The reason the OD light flashes is the PCM thinks there is a fault in the TC lockup circuit, provide it with the nessesary resistance, and it should be happy.
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #7 of 17 Old 03-30-2008, 10:00 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
Thats what i was thinkin about doin. So basically as long as i have the resisted load going to the PCM, i can have it manually locked or unlocked and it wont flash?
BPS President
Jake is offline
post #8 of 17 Old 03-30-2008, 10:01 PM
John Wood Nut Swinger
strokin_early_99's Avatar
Yup it was me. I sled pull with the TC manually unlocked plus my DP tuner has the lockup set at 47mph. Like I would ever hit 47mph in 4low on the sled pull track but I like redundant systems...LOL
I have also used it to unlock the TC while towing in the mountains and I got stuck behind another RV. I needed a few more RPM to keep the EGT's in check with my old turbo setup. I just flipped the switch and the RPM increased about 900rpm and the EGT's dropped. FWIW, The trans never got over 185*.
The big thing is to never let the PCM see more then 5Volts. That is the maximum feedback voltage from any of the sensors on the truck. More than 5V and you will fry the PCM.
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
post #9 of 17 Old 03-30-2008, 10:05 PM Thread Starter
PMR = JUNK
Jake's Avatar
Quoted: 4 Post(s)
So im assuming the 20,000 ohm resistor used in guzzles method takes it down to 5v? Don't they have diodes that limit voltage? which would be better?
BPS President
Jake is offline
post #10 of 17 Old 03-30-2008, 11:20 PM
99bigred's Avatar
wouldnt you still get a trans slip code?
early 99 f-350 7.3 6speed crew cab
banks exhaust, chip, big head, exhaust houseing
and wheel
Ford AIS intake
5.5" fabtech lift w/ 35x12.50/18's
99bigred is offline
