Foil Delete
Going to do the foil delete today. Any pointers before i head out?
make sure you have a solvent or goo gone to get rid of the glue. I didnt and had to go for a little walk the other day
dont forget pics
If you have a drill and a 2" or 3 " wire wheel that is made too use with a drill. The job takes about 15 min. Leaves the tube like brushed aluminum. Didn't need any chemicals at all.
do u just rip it off and clean off the glue ????
should i take off the pipe first ??? |
take off the tube, it will make life much more enjoyable. It only takes 2 mins to take it off
awesome man thanks
right on man!!! enjoy the louder turbo scream!!
haha yea. Chris, take of the tube, then rip off the foil, WEAR GLOVES! that foil is pretty sharp. I wore some machanics gloves. If you want to use the drill with the wire bit, it scrathes it up alot. This took me quite a while to do. I peeled as musch stuff off with my hands as i could, then soaked it with WD40 and Carb cleaner. I also tried Texsolve and this stuff called chem-dip. I threw almost all the chemicals we had on the shelf on the pipe. Then took a flat razor blade and scraped most of it off. Then i used steel wool on it, the superfine grit 0000 (all i had) and cleaned it up as much as i could.
Ill go take some pictures right now. |
i meant 2 minutes to take the pipe off
