Disconnecting EBPV? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-24-2013, 12:00 PM Thread Starter
jdereu's Avatar
Disconnecting EBPV?
Im having some issues with my truck leading me to an EBPV acting up. I know the best course of action is to gut it or get a new pedistal but as of now i dont really have time to do that. So right now i just want to disconnect it and use the resistor from pure diesel (99-03 Ford 7.3L Powerstroke Exhaust Backpressure Valve Terminator)
Am I going to run into any issues doing this?
2000 Ford F-250, Crew Cab Long Bed 4x4, Automatic Transmission, Ts 6 Position, 4" MBRP Exhaust, DIY Intake, Pillar Guages, CCV Mod
jdereu is offline
post #2 of 13 Old 06-24-2013, 07:03 PM
timmyboy76's Avatar
mines gutted and resisted with a diode from radio shack..$1.00
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 13 Old 06-24-2013, 07:47 PM
c69ss396's Avatar
unplug it and wire it open, They will close even when unplugged for some reason..
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #4 of 13 Old 06-24-2013, 08:08 PM Thread Starter
jdereu's Avatar
So I don't need that thing from pure diesel? What size diode and how do I wire it open
jdereu is offline
post #5 of 13 Old 06-25-2013, 12:54 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Unplug the sensor itself that's easy.
As for wiring it open, disconnect the actuator rod and just wrap some mechanic's wire around the butterfly and then to the intake spider to hold it open.
For the record, I'm in Canada, -30C starts in winter time and mine has been wired open since very shortly after i got the truck... no issues.
schlutzer is offline
post #6 of 13 Old 06-25-2013, 04:35 AM Thread Starter
jdereu's Avatar
So is that actuator arm next to the plug im unplugging?
jdereu is offline
post #7 of 13 Old 06-25-2013, 03:49 PM
schlutzer's Avatar
Quoted: 18 Post(s)
Yup its on the underside of the turbo outlet once you get your hands down there you'll see it's pretty simple could be done in 5 minutes.
post #8 of 13 Old 06-25-2013, 04:03 PM Thread Starter
jdereu's Avatar
I see the plug but I don't see anything that looks like it can be wired haha anyone have a picture?
jdereu is offline
post #9 of 13 Old 06-25-2013, 04:06 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Wired as in with baling wire. There is an arm coming out of the pedestal at the bottom to the housing AFTER the exhaust housing.
The Dfuser or Pure Diesel or diode will just keep from storing a soft code.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 13 Old 06-25-2013, 05:08 PM Thread Starter
jdereu's Avatar
o ill have to dig in and see. Im sure ill find it. what size diode would I use
jdereu is offline
