At wot it seems to fall on its face - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-22-2013, 09:10 PM Thread Starter
F350oldskool's Avatar
Hey guys, my 01 was running real strong when I first put the majority of my mods on. Just recently I did the ccv mod and I also installed the riffraff frx. Truck ran a lot better. But today I took it out and it seems to fall out at wot. Like it will build boost, 23-24 and it will just kinda not go anymore. Feels like its goin as fast as it will go. I don't see any leaks on my up pipes, I check them thou roughly tomorrow but. Could it be a hpop or a boost leak? I know my clutch its old and loud could it be slipping that bad? Any suggestions would be great. Thanks
2001 F250 SD ZF6
4in MBRP straight
DIY intake
TS 6 pos chip
HPX
FRX
CCV mod
Boost fooler
Wicked wheel
She aint the fastest but she runs good
Jeremy- Ft. Collins, CO
[URL=http://s1251.photobucket.com/user/F350oldskool/media/image.jpg.html]
F350oldskool is offline
post #2 of 16 Old 06-23-2013, 12:40 AM
JSchuricht's Avatar
If you didn't have a boost fooler, I would think your defueling which happens right about 24 psi. It could be your stock wastegate opening, try unplugging the red line. Also check your ICP, you could just be running out of oil on the top end.
JSchuricht is offline
post #3 of 16 Old 06-23-2013, 06:27 AM Thread Starter
I got the waste gate unplugged and I just replaced icp about three weeks ago. I'm stumped lol
2001 F250 SD ZF6
4in MBRP straight
DIY intake
TS 6 pos chip
HPX
FRX
CCV mod
Boost fooler
Wicked wheel
post #4 of 16 Old 06-23-2013, 12:09 PM
Joel's Avatar
Quoted: 10 Post(s)
Try the IPR
Mine was faulty. It didn't throw codes and the truck ran fine. But when I replaced it in search of my power loss the truck gained back my top end power.
Along the way I replaced up pipes, turbo wheel, ICP, added a fuel pressure gauge and the biggest difference was the IPR
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #5 of 16 Old 06-23-2013, 12:11 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You can try stuff all day long. It could be lack of high pressure oil, lack of fuel pressure, or just defueling as stated. Monitoring live data will tell you what it is/isn't.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 16 Old 06-23-2013, 12:30 PM
Joel's Avatar
Quoted: 10 Post(s)
Yes that is correct. Sorry I should have been clearer on that.
In my case, all the things I replaced did need to be replaced, just the IPR made the biggest difference to me.
I use the edge insight for data monitoring and that's how I came to replace the IPR in the first place
Joel is offline
post #7 of 16 Old 06-23-2013, 04:49 PM
Codum's Avatar
I would check fuel pressure at WOT first.
2002 F250 CCSB Lariet 7.3 Auto
2" helper springs 285/75R16 Toyo M/T
80 gallon fuel tank in bed
DIY 6637
Warn Premium Hubs
Ford Transmission @ 407,425 miles 3/24/12
Full Force Injectors
Avic X930BT w/ backup camera
"We Farm for Ducks"
As of 6/11/16 605,552 miles
2005 Excursion Eddie Bauer 4X4 6.0
Stock 225k miles
Codum is offline
post #8 of 16 Old 06-23-2013, 04:50 PM
how about a hole rubbed through the map sensor boost line?
cfd_shop is offline
post #9 of 16 Old 06-23-2013, 05:47 PM
jesilvas's Avatar
Quoted: 2 Post(s)
That should affect all aspects of acceleration and mileage, not just the top end.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 16 Old 07-20-2013, 07:31 AM Thread Starter
I had a modis scanner on if but it couldn't read fuel pressure for some reason, where can I put a mechanical gauge?
2001 F250 SD ZF6
4in MBRP straight
DIY intake
TS 6 pos chip
HPX
FRX
CCV mod
Boost fooler
Wicked wheel
