Cb radio and six gun gauge problem - Ford Powerstroke Diesel Forum
post #1 of 27 Old 06-22-2013, 04:57 PM Thread Starter
Everytime I key my mic to talk on the cb radio my truck will change idle and drop 200 RPMS. Also my egt gauge/6 gun tuner will drop to a temp of 32 degrees even at 200 degrees idling not keyed. Why? When I hold the antenna with my hand nothing happens everything is good.
hondaracer315 is offline
post #2 of 27 Old 06-22-2013, 05:29 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Is your antenna grounded?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 27 Old 06-22-2013, 05:44 PM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
your cb/antenna isnt set up right..
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #4 of 27 Old 06-22-2013, 07:30 PM Thread Starter
We tried everything possible nothing has changed. Ran the power directly to the battery. I even alleviated the truck source by using a booster jumper pack with a cigarette lighter attached to the booster pack still same thing. The only way is if I touch the antenna the six gun is not affected and the idle doesn't change. I tried the little wil with a uniden pc78ltw, I also I tried a fire stick. With the firestick if I touch the screwdriver to the antenna and to the grounding plate on the bed no problem. So I'm guessing I'm using non grounding plane antennas.
post #5 of 27 Old 06-22-2013, 07:38 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You always should ground. With as short a ground as possible too.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 27 Old 06-22-2013, 07:47 PM Thread Starter
How do I ground the antenna?
post #7 of 27 Old 06-22-2013, 07:51 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You ground the mount, and have proper spacers between the antenna and mount.
The ground is also the shielding of the coax, and the center strand is connected to the antenna itself.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 27 Old 06-22-2013, 07:54 PM
Macon's Avatar
Take a pic of how your antenna is set up, please.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #9 of 27 Old 06-22-2013, 07:59 PM Thread Starter
I did mine just like that I used a bed stake mount from firestik sl-194a. I was told that there is a firestik antenna with a ground coming out of it on the bottom of the sheath. I even uncovered the coax cable and undid the ground strands and hooked it up with stakeons sorry for the spelling of that. I am guessing I need an antenna with a ground plane? Ever heard of the antenna with a ground cable coming out of it?
post #10 of 27 Old 06-22-2013, 07:59 PM Thread Starter
How do I post the picture on here?
