Turbo boost defueling point? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-22-2013, 02:41 PM Thread Starter
Does anyone know if there is a exact point (boost PSI) at which the computer (02 f350) will defuel a chipped up engine?
ie When do you need to add a boost fooler to keep the computer from overriding the chip?
thanks Fletcher
2002
350 4X4 Dually Crew Cab
S&B intake
Edge Evo2
TW 6position chip
stage 1 Injectors
ATS turbo Housing
4"Magnaflow turbo back stainless exhaust
Rear load leveler Air ride
Rancho air adjustable shocks all 4 corners
B&W goosneck hitch
SCDEALER is offline
post #2 of 9 Old 06-22-2013, 02:53 PM
jesilvas's Avatar
Quoted: 2 Post(s)
IIRC it's 24PSI.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 9 Old 06-22-2013, 03:19 PM
Quoted: 12 Post(s)
Feedback Score: 3 reviews
yep, 24. i just got my ww2 on and that is where mine is cutting off. any particular brand better than another?
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 9 Old 06-22-2013, 03:28 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Driven Diesel Overboost Annihilator
Riffraff Diesel: OCR - Overboost Code Regulator
Those two look the same. Seem to be able to regulate them.
Idk why but I like this one more.
http://www.dieselsite.com/boostreliefvalve.aspx
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 9 Old 06-22-2013, 03:36 PM
Quoted: 12 Post(s)
i guess i have some more money to spend.
post #6 of 9 Old 06-22-2013, 04:01 PM
Joel's Avatar
Quoted: 10 Post(s)
Don't half decent tunes prevent the defuling symptom?
I took my boost fooler off and the truck runs better.
The CEL comes on all the time, but the truck is definitely stronger for some reason.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #7 of 9 Old 06-22-2013, 04:13 PM
Macon's Avatar
thanks Fletcher
Contact your tuner and ask them what it's set at. I think all of the tuners remove defueling altogether, but they could simply raise the point at which it occurs. 24psi is the factory defuel point, and if you're running a stock turbo, it coincides with the waste gate dumping point as well.
Valid safety positions if you don't want to grenade the factory turbo. If you were to upgrade the wheel or the full housing, then the safety points change and everything factory becomes null. There are ways to get more boost out of a stock unit, but anything above 30psi starts to get dangerous (longevity wise). If you want more boost, change the wheel or housing. Aftermarket will spool up faster and boost higher. Pushing stock to the limit is nothing more than polishing a turd.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #8 of 9 Old 06-22-2013, 05:42 PM Thread Starter
Thanks for the replies. I have a TW chip and it seems to pull back when the boost hits 26psi, just wanted to confirm what I suspected.
2002
S&B intake
Edge Evo2
TW 6position chip
stage 1 Injectors
ATS turbo Housing
B&W goosneck hitch
SCDEALER is offline
post #9 of 9 Old 06-22-2013, 07:51 PM
Macon's Avatar
Email them and see what's up. I would guess that your waste gate is opened up and that's what you're feeling. Is it blowing smoke?
2002 F250 CCSB 4x4
Macon is offline
