Identifying powersteering lines - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-21-2013, 06:21 AM Thread Starter
mcyrana's Avatar
Im replacing my gearbox in my truck and im replacing the one line that probably caused to to go bad since its pretty leaky (the metal clamp on top wore though the line on the bottom)
But i need to know which one is the pressure and which on is the return. The line in looking to replace is the furthest to the front on the box and is on the driver side of the hydro boost
Originally Posted by dentexpowerstroke View Post
I've already explained that to him multiple times tho and he doesn't understand... Im about to bust out some crayons and draw it for him.
6637 Filter, Warn locking Hubs, Recon LED Cablights, Leveled 2", 8" CAT Stack, 35" Goodyear Duratracs, High pressure oil crossover tube
mcyrana is offline
post #2 of 2 Old 06-21-2013, 08:18 AM
russtwentyfour's Avatar
I would just replace both so no worries later on, they are listed on oriellys for $40 for high pressure and $20 for return both gates which are good quality. Or just go to oriellys website and look at what they have and match up with the pics? Hope this helps!
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
