4x4 "SOTF" and Manual Hub Position - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-20-2013, 06:57 PM Thread Starter
Question 4x4 "SOTF" and Manual Hub Position
Hi all! As the title suggests, I have shift-on-the-fly (2WD / 4H / 4L), and manual hubs. From what I've read elsewhere, that is stock for my truck. The markings on the manual locks are gone, and I don't want to ruin anything.
I assume "free" is normal 2WD mode, but because the markings are gone, I'm not clear on which direction to turn them for "free" / 2WD, and do I need to manually lock those in for 4WD, while also using the "sotf" switch inside the cab?
Description of my rig is in the signature. Much obliged!
2001 F350 Lariat 7.3L 4x4 CC SB
BFG-AT 35x12.50R16.5, 4" Lift 173,000mi...so far
RafterQ is offline
post #2 of 9 Old 06-20-2013, 08:00 PM
Zaairman's Avatar
Quoted: 12 Post(s)
Lefty loosey (unlocked/auto) righty tighty (locked). If they operate correctly, you just need to flick the switch on the dash.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 9 Old 06-20-2013, 08:01 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
the system is called ESOF or electronic switch on the fly.
their is vacuum lines that run to the hubs that engage them.
check these lines they often get dry rotted and wont hold pressure to engage the hubs.
and yes you can lock them at the hubs.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 9 Old 06-20-2013, 11:19 PM
alaskan155's Avatar
Quoted: 60 Post(s)
when it pops its locked in 4wd, you will feel it when turn the hub, one of mine are worn and the other isn"t and that's how i can tell
free/auto mode dosen't have the pop when you turn it. takes some resistance to unlock the hubs
you can also turn the wheel and reach around the tire and try to turn the axle shaft by hand. if it turns your hubs are unlocked
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #5 of 9 Old 06-21-2013, 04:10 AM Thread Starter
Thanks for the help, hope to return the favor! When you say flick the switch on dash, do you mean the ESOF dial, or the toggle I have next to it that doesn't seem to operate anything? Could that be a stock switch as well?
RafterQ is offline
post #6 of 9 Old 06-21-2013, 09:30 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
The ESOF dial only.
We would have to see a picture of the toggle switch to tell if it is factory or not.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #7 of 9 Old 06-21-2013, 03:09 PM Thread Starter
Sorry, shoulda thought of that Hey, Greg...we moved back out to KC from Santa Rosa in '97. Have things changed much? I miss the In 'N Out Burger in Rhonert Park badly, and it almost kept us from moving..heh heh.
RafterQ is offline
post #8 of 9 Old 06-21-2013, 03:14 PM
ZMANN's Avatar
Quoted: 1566 Post(s)
Togggle is non OEM
fog lights ?
We Miss you Ronnie
ZMANN is online now
post #9 of 9 Old 06-21-2013, 03:47 PM Thread Starter
Fog lights work by pulling out on the OEM headlights dial...hmmm. Of course the feller I bought it from, doesn't know what it does (I'm the 7th owner). He didn't know what the loose wire hanging down under the dash is for, or why the turbo boost gauge isn't getting power, which is fine, if he told me the truth. If he didn't, how much more helpful would it be to me to know the real scoop? Not like, at that price I wouldn't have bought it anyway, I reckon.
RafterQ is offline
