fuel line repaired - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-20-2013, 05:11 PM Thread Starter
blue99stroker's Avatar
Quoted: 249 Post(s)
fuel line repaired
well yesterday i changed some of the hard fuel lines out on my truck
the passenger side one wasnt too bad. i cut off the old line right at the fitting and used a ratchet to take it off. wayyyy easier.
instead of using a shorty wrench i reached under the pedestal (long and skinny arms) and tightened the new line down using a regular size crescent. then the fitting on the fuel bowl was a piece of cake.
now the drivers side fuel line is another story.
it runs under the fuel bowl and hpop and is a pain in the *&% to get out.
i ended up having to loosen the power steering bracket, remove the alternator to even get to the fitting on the head. crows foot wouldnt work for me.
took me a while to get it out too, ended up bending it too get it out.
the new one was a challenge to get in too. seems like every wire is in the way lol
but with a little bit of sweat (and blood) finally got the sucker in their.
so if anyone is planning on replacing the drivers side line it is not fun and i hope this helps.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #2 of 3 Old 06-20-2013, 09:54 PM
I did the p/s one last night and cut the end off at the head as well. I had a look at the d/s line and it looked like a lot of screwing around!
Greenman01 is offline
post #3 of 3 Old 06-20-2013, 10:47 PM Thread Starter
Quoted: 249 Post(s)
it takes a lot of wiggling.
it was difficult just to remove it. install was hard because i didnt want to ruin the new line.
but i bent the new line just slightly to get it back in.
it took lots of patience and mine was starting to wear a little thin.
now i want to get the Frx from riff raff and their new billet compressor wheel
