unidentified 2 pin harness - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-20-2013, 04:00 PM Thread Starter
Question unidentified 2 pin harness
hi while looking under the truck , i noticed a 2 pin harness with a "x-mas" tree barbed clip still attached loose under the truck. it hasn't been connected to anything in sometime according to the corrosion of the female pin slots. It is hanging on the d/s front fender, actually in the space underneath, between the fender liner and the floor board of the cab. i noticed it when i was under looking at the oil pan and such. The harness seems to have come down from under the hood, in the area where the fuses and relays are. It is NOT the air box temp sensor harness. I have no codes to help me and everything seems to work. What could it be?
lght1 is offline
post #2 of 10 Old 06-20-2013, 04:11 PM
aussie=effie
bob harris's Avatar
Question harness
maybe wiring for reversing light ??
bob harris is offline
post #3 of 10 Old 06-20-2013, 04:14 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
my dads f250 and mine have the same connector it just hangs out their with nothing plugged into it.
i cant remember what its for at the moment.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #4 of 10 Old 06-20-2013, 04:33 PM
goats's Avatar
Quoted: 2 Post(s)
Might be the abs sensor plug,there should also be one on the pass side as well.
goats is offline
post #5 of 10 Old 06-20-2013, 04:48 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
do you have fog lights?... if not may be the plug for the fogs
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #6 of 10 Old 06-20-2013, 10:30 PM
timmyboy76's Avatar
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #7 of 10 Old 06-22-2013, 06:59 AM Thread Starter
hi others have said abs as well. i will have to check later to see if the rig has abs on the front. i am told some did not in '99
lght1 is offline
post #8 of 10 Old 06-22-2013, 02:16 PM
What size wires? My block heater wires dangle/tuck behind the front bumper area. Has had the actual plug cut off by previous owner.
Gchapell is offline
post #9 of 10 Old 06-22-2013, 03:18 PM
Macon's Avatar
Whether the truck came with it or not, doesn't necessarily affect the wire loom. You'll find most things have the wires laid out, just not connected to the end user options. Like the over head console, electric seats, ambulance package...
In any event, pictures are worth all the words you could type.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #10 of 10 Old 06-23-2013, 07:56 AM Thread Starter
It would if the truck had front abs and the respective harnesses were or were not plugged in. Its just a two pin connector with a barbed christmas tree a few inches up on the loom. its been unplugged sometime based on the corrosion inside the connector.
lght1 is offline
