Thoughts on hub centric wheel spacers?? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 06-18-2013, 04:03 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
Title says it all. Was thinking about installing a 4" lift and 35's on my 2000 cclb 4x4. I like my stock lariat wheels and don't wanna have to shell out more $$$$ for wheels if I don't have to. Was thinking that 2" spacers would allow me enough room to turn with 35's and not rub. What do y'all think?
cummin is the mess left behind by strokin!!
2000 7.3l f350 4x4 cclb psd. 4r100 trans.Ranchhand everything! 6637 intake, zoodad mod, custom big rig runnin lights, ccv mod, RR boots and plenum inserts, foil delete, EV2 gauges, edge cts, tuff country 2.5" leveling kit, X codes, 315/75r16 coopers, 08 mirrors, 6.0 trans cooler, tgc dual steering stabilizer, fabtech adj. trac bar, mbrp 5" turbo back straight pipe with 8" tip, php 6pos, ssbc brakes, ebpv delete, cat elc 100,xxx
Ford Cowboy is offline
post #2 of 16 Old 06-18-2013, 04:28 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
With a 4 inch lift, you should have no probs running 35s by them selves
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 16 Old 06-18-2013, 04:37 PM Thread Starter
Quoted: 5 Post(s)
I've read mixed reviews where people say they don't rub or they rub only slightly with a 4" lift and 35's. I want ZERO rub, on stock wheels and think that spacers might get me there. Just don't know what the consensus is on a good qaulity set of spacers. My buddy has same year truck with x code springs and a leveling kit on stock wheels with 315's and they rub his front springs pretty good.
Just FYI the spacers I've been lookin at are from wheeladapters.com. 2" thick steel spacers
post #4 of 16 Old 06-18-2013, 07:01 PM
SOHCPOWER's Avatar
Those spacers you are talking about from Fred are amazing. I have a set on my dually and I have no shakes. I feel so much better about running good quality steel spacers over the Chinese aluminum units.
I found other steel unit's on Ebay from a guy in texas. They were over 300 dollars and when I got them I realized he didn't make them hub-centric. I returned them and bought the good ones from Fred. I tried to save a few dollars and failed. Oh well.
2000 F-250 7.3 CCSB 4x4 7.3
2007 F-550 CCLB 2wd 6.0
2003 F-550 Reg Cab 2wd 7.3
2003 F-350 CCLB 4x4 76.0
7.3 powerstroke repair/enthusiast for ten years.
SOHCPOWER is offline
post #5 of 16 Old 06-18-2013, 07:22 PM
Doesn't Even Care
Quoted: 69 Post(s)
Yep get them from Fred. That's where mine came from
Nick
"The Mistress"
post #6 of 16 Old 06-18-2013, 07:28 PM
Quoted: 17 Post(s)
I used 1.75 2 piece aluminum wheel adaptors on my Jeep, took 5 lug to 8 on 170. I bought them from Motorsport tech & they are hub-centric. They made them custom for me & were like 200$
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #7 of 16 Old 06-18-2013, 11:11 PM
Quoted: 769 Post(s)
I have 35's and they definitely rub. Also have the x code springs. No lift. They just rub the leafs. I was thinking about using non bolt on spacers and I think I can get away with one inch spacers with longer studs from Fastenal. Not the bolt to bolt style. ????
Corey@CNCFAB is offline
post #8 of 16 Old 06-19-2013, 06:15 AM
chrispaine's Avatar
I have some wheelspacer.com aluminum spacers that I picked up for a good deal, don't have a ton of miles on them but you can see/feel quality in them. No rub with 315/70/17's
2000 F250 7.3L EX.Cab Short Bed -05 Front end w/ HID's - Leveling shackles - Wicked wheel - Dipricol gauges - FORD AIS intake - Foil Delete - LINE-X Rockers - CCV dump - 315/70/17 BFG A/T with Eagle Alloy 197's - ELC w/ coolant filter and around the belt hose - PHP Hydra - Hpress oil x
On the way--
-Fusion front bumper - ATS 3" fender flares
chrispaine is offline
post #9 of 16 Old 06-19-2013, 12:27 PM
Doesn't Even Care
Quoted: 69 Post(s)
Using them on your jeep is totally different than the strain and load and weight that our trucks will put on them. Wheeladapter.com is Freds site
Nick
"The Mistress"
post #10 of 16 Old 06-19-2013, 04:57 PM Thread Starter
Quoted: 5 Post(s)
Cool! I'm most likely gonna go with Fred's spacers( unless I can find better spacers, which I don't think I will). Do y'all think that 2" spacers will give me the clearance off the front springs for 35's?
