Old 03-25-2008, 03:52 PM
siloped siloped is offline
4r100 to 6 speed swap
Myh tranny is on its last leg and I'm having a hard time saving the dimes to get a quality rebuild. I'm trying to get in touch with a guy who is parting out an 01 powerstroke w/ a stick to find out if it would save me a few bucks to do a conversion to a 6 speed. What are your thoughts on this or if you know anyplace that fill work out a payment plan on a quality built tranny.
Old 03-25-2008, 05:00 PM
CSIPSD CSIPSD is offline
You will spend more on a 6 speed converson then a built auto... Get a loan and buy right...
Old 03-25-2008, 05:42 PM
sflem849 sflem849 is offline
Swapping your motor into his truck would probably be cheaper than the trans conversion.
Old 03-25-2008, 06:03 PM
EVen if i get the trans pedal assembly and shifter for a reasonable price and do the swap myself? The only other option i got is a local ford trans specialist that will assemble a monster box for 2200. No can do on the loan, had to do that a few months ago for the injectors
Old 03-25-2008, 06:04 PM
Going to have to get the PCM, the Res, the tranny, the pedals, cut a hole in the floor... You can if you want too... but its going to cost you more then 2k in the end... if you do it cheapo...
Old 03-25-2008, 06:45 PM
Did not know about the pcm. So i guess thats not the way to go. Lets just say for argument sake that if i could get the parts for under 2k, do you think it would be worth the effort, or stick with the auto since i do tow my jeep around a few times a month? I would like your oppinion since i've spoke with you a few times on here before and you seem pretty knowagable.
Old 03-25-2008, 06:52 PM
Sun Coast Converters Diesel Transmissions, Fort Walton Beach FL
I have about 2500 in parts in my tranny... all suncoast, thats Billet input, and a tripple disk TC... Total was $4000 installed.
You dont need the billet stuff so I bet you could get all the parts for about $1800 and be off and running.
