Rear leaf spring rubbers - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-17-2013, 07:29 AM Thread Starter
chevelless414's Avatar
Looking to replace the factory rear leaf spring rubbers {1missing} these are the ones mounted on the springs themselves help with axle wrap. After searching i can't seem to find a part number. Anyone help me out?
2002 Excursion 7.3
6637 filter
gauges
v&b code spring swap
hellwig rear sway bar
4" mbrp exhaust
DP- Tuning
wicked wheel
ebpv delete
chevelless414 is offline
post #2 of 4 Old 06-17-2013, 07:40 AM
ZMANN's Avatar
Quoted: 1670 Post(s)
the sliders or anti friction pads? they have nothing to do with spring wrap
if your springs are OEM ? Ford may sell them ?
but many online sellers have them( use keyword Anti Friction IIRC) or you local spring shop should also
there are many sizes so measure first
if you want dissemble the whole spring clean the rust with a wire wheel and sanding disks , releive any sharp edges at the spring ends , paint, and then I use graphite paste between the springs ( it repels water and is slick as hell) then new anti friction pads /center bolt/ and u can replace bushings if need be for a better than new ride
We Miss you Ronnie
ZMANN is offline
post #3 of 4 Old 06-17-2013, 01:29 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You don't need or use the Excursion rear bottom 1/2 bar with the rubber snubber when doing the B mod swap.
CT Performance, Inc. is offline
post #4 of 4 Old 06-18-2013, 06:15 AM Thread Starter
Thanks Cary this is for another X it still has stock springs all around. Not ready to do swap yet
2002 Excursion 7.3
6637 filter
gauges
4" mbrp exhaust
DP- Tuning
wicked wheel
ebpv delete
