Old 03-24-2008, 04:28 PM
black99stroker black99stroker is offline
Egt temp
I installed an autometer boost and egt guage about a month ago. I am starting to think that the egt guage is not working properly because it never climbs over 700 degrees. Even towing my car trailer it never gets any higher. Could this be normal or is the guage messed up? Thanks
Old 03-24-2008, 04:29 PM
Marty Marty is offline
International Threat
Is your truck chipped or programmed?
Old 03-24-2008, 04:30 PM
It has a edge evolution programmer and just straight piped the stock exhaust.
Old 03-24-2008, 04:31 PM
DuraWhat? DuraWhat? is offline
Well I mine can go over 700 just running down the highway climbing a hill at 80. With a trailer and a car and it doesnt go over 700 I would def say something is up. How fast are you running? Is it mostly flat ground? Seems really low, but there are people on here alot better at these questions then me. So heres a long drawn out bump
Old 03-24-2008, 04:33 PM
Yeah, I'd try another gauge then.
EDGE = 1200 degree's quick...
Old 03-24-2008, 04:35 PM
With my camaro on the trailer it doesn't matter if im going up a slight grade or just running down the highway its about the same. Never seen it over 700.
Old 03-24-2008, 09:48 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Where is the probe located? If you only see 700* pre turbo then the gauge is bad or you have a bad connection. Even stock I could see 1150* pre turbo.
Old 03-24-2008, 10:21 PM
The probe is in the drivers side up pipe, pretty close to the manifold. My buddy bought the same guages, im going to borrow his and see what happens. Thanks for the help.
Old 03-25-2008, 03:36 AM
Southpaw Southpaw is offline
1/20/2013
This will sound stupid - but what kind of gaugesdo you have?, and do you have a CB radio in the truck?
Old 03-25-2008, 07:19 AM
tubular031 tubular031 is offline
man i hit 1250 just getting on the freeway! usually i back off at 70 mph which is right around the time the egts get too high.
