  #11 (permalink)
Old 03-25-2008, 07:44 AM
dmbrichie dmbrichie is offline
Well my Isspro gauges never get over 400, I have replaced the gauge and the wiring box once already, still never over 400... Something is def. wrong with mine...
  #12 (permalink)
Old 03-25-2008, 07:48 AM
cchase cchase is offline
is it bad that i put mine right after the turbo on the pass. side?
  #13 (permalink)
Old 03-25-2008, 07:59 AM
tubular031 tubular031 is offline
Not bad, just different info being displayed. i dont remember the numbers but the max temp is MUCH lower then a pre turbo .
its probably a good idea to plug that hole and tap one on the drivers exhaust man.
It is actually pretty easy. the hardest part was trying to figure out where to put the hole so that the drill and tap would fit around all the things in the way (suspension and all) and then making sure that you can turn the tap with out the handle hitting everything.
  #14 (permalink)
Old 03-25-2008, 08:48 AM
Anthony2447 Anthony2447 is offline
<--Chicks Machine
Send a message via AIM to Anthony2447
I read somewhere if its after turbo then its around 300* difference then pre turbo.. so if your not tryin to go over 1250-1300 you want to stay around 950-1000 after turbo.. like i said im not completely positive though
  #15 (permalink)
Old 03-25-2008, 10:04 AM
i remember reading something from strokin early 99 where he said it was further off as the boost rises. i think banks said that too (dont hate, i was new and did not know!)
  #16 (permalink)
Old 03-25-2008, 10:48 AM
CSIPSD CSIPSD is offline
Yes, its bad if it is post turbo. Your EGT's could be as little as 100 or as much as 500 off... Move it to the pre turbo location or add a second gauge...
  #17 (permalink)
Old 03-26-2008, 03:03 AM
Southpaw Southpaw is offline
1/20/2013
Now how did we know that would be your response?
  #18 (permalink)
Old 03-26-2008, 06:54 AM
03_Turbo7.3 03_Turbo7.3 is offline
Hey,
if its after the turbo you want to setyour "alert" function if you have one around 1100-1180 i was told by NADP, i put mine after my turbo and hit numbers up to 850 if im baggin on her, usually highway is NEVER more then 450-550 depending on terrain, what setting is your programmer on? im running the Edge evo with EGT display and have it on the highest setting and i cant get over 900 im sure i could if i really beat on her but i like my beast and want to have her around forever...just my 0.02
