Some numbers to share (help) - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-15-2013, 08:00 PM Thread Starter
AnthonyU's Avatar
Quoted: 8 Post(s)
I have some numbers I want to share with you guys and get your thoughts and ideas what the issue might be. I took my chip out to see if the problem went away and it did.
Truck. 2003 f 350 dieselsite hpop shock injectors, R.R. Exhaust ww2 PHP TUNES
With chip hitting WOT I get a p1211.
with out the PHP tuner
Idle
Icp 475 Ipr 8.2
WOT
Icp. 2850 Ipr 38.3 %
with the tuner in ( PHP).
Icp is at 2850. Ipr is at Over 90%
and I am getting a P1211 all the time
Thanks for the help
AnthonyU is offline
post #2 of 3 Old 06-15-2013, 09:14 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
check your icp senser.
if theirs oil coming through its bad.
next thing would a IPR.
reman from dieselite is 80 bucks.
your not getting enough oil it sounds like.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #3 of 3 Old 06-16-2013, 08:01 AM
Joel's Avatar
Quoted: 10 Post(s)
Your ICP pressure is higher than mine with the tune.
Mine runs over 90% and at about 1800 psi if i stay in it.
I replaced my IPR and the truck ran a lot smoother and helped a little with the numbers.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
