chassis flex/twist - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-14-2013, 01:08 PM Thread Starter
AUSPowerstroke's Avatar
chassis flex/twist
Just a quick question, I have never really been to concerned about it, always thought if it wasn't meant to do it it wouldn't hahah, but one of my mates has been in my ear about the chassis flex my F250 gets in some Offroad situations, I do a lot of Offroad work at some times I'll have wheels off the ground and it will be all twisted up, I haven't had any issues yet but is there know problems from the chassis flexing or is it all good?
2003 F250 7.3l (RHD), auto, 4"lift, 315/75R16's, arb steel winch bar, 12,000lb winch, 30" LEDlightbar and 2x lightforce 240 spotlights, Snorkel, edge cts attitude tuner, 5"stright through exhaust, Custom made rock sliders, Front and Rear ARB air lockers, still more on the list to be done
AUSPowerstroke is offline
post #2 of 5 Old 06-14-2013, 01:19 PM
alaskan155's Avatar
Quoted: 60 Post(s)
its all good,
if your offroading it alot just watch the factory rivets, that would be the only weakness over time, they can come loose around the crossmembers
if its offroad more than it is onroad you could try removing the sway bars/setup a quick disconnect and let the suspension do more of the work .
but frame flex is normal, its a c-channel frame,
next time look at a big rig, which get loaded up to 80-100k lbs, and running a c-channel or a duce and half, on both of them, the frame flexes for years and nothing happens.
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 5 Old 06-14-2013, 01:22 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
If this guys frame didnt snap, i think yours will be fine JK
2000-7.3L is offline
post #4 of 5 Old 06-14-2013, 01:24 PM Thread Starter
Originally Posted by alaskan155 View Post
its all good,
if your offroading it alot just watch the factory rivets, that would be the only weakness over time, they can come loosed around the crossmembers
next time look at a big rig, which get loaded up to 80-100k lbs, and running a c-channel or a duce and half, both of them the frame flexes for years and nothing happens.
I've already removed the sway bars but yeah it does on road and Offroad work
That's that's what I thought and why I was never really concerned but my mate was constantly telling me about it so thought id ask, thanks
post #5 of 5 Old 06-17-2013, 05:19 PM
Quoted: 14 Post(s)
No flex = cracked frame and other bits. Frames are supposed to flex some.
ttyR2 is offline
