- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
O rings and exhaust housing installs ?
I have an oil leak and I can not seem to figure out where the heck it’s coming from! So I did some reading and read that turbo o rings and the HPOP line o rings leak a lot. So I bought both and will be replacing them at the same time. I found a good write up on how to do the turbo o rings. (thanks maintain!)
So now I need some info on installing the HPOP line o rings and also while I have the turbo out I want to install a bigger exhaust housing and maybe even a Wicked wheel. Anyone know of a write up on the HPOP o rings and how to install an exhaust housing on the stock turbo? O an which exhaust housing should I get? Wastegated? Non wastegated? What size? |
| Sponsored Links |
Here you go here is a nice writeup http://www.powerstroke.org/forum/7-3...o-rebuild.html
Just take your time and do all 3 while you're in there. The ones at the heads normally do not leak... but they are the same thing... fitting with an O ring. Did you see my writeup for removing the turbo? If so it's pretty simple... I've also got video's if you need them on that. Make sure you have the CORRECT SIZE 12 POINT socket for the exhaust side. 3/8's drive or bigger is best to use and a small cheater bar helps. Make sure you put good, even pressure on them otherwise you can strip them. The exhaust housing is a bolt off, bolt on deal, and the wicked wheel I have a video of too. Looks like you're set! |
Yup i got all your vids maintain. thanks for those
Now I just gotta get better! stupid messed up arm!! |
| Sponsored Links |
