Old 03-22-2008, 10:25 PM
ghost rider ghost rider is offline
Battery Light coming on in Dash??
My Battery light is coming on every now and then. More times being when my foot is not on the gas, but coasting or on the brake. What is this light trying to tell me??
Rob
Old 03-22-2008, 11:08 PM
99bigred 99bigred is offline
your alt it probably getting ready to go out. or else the wire on the back of it is gettin coroded and not making good contact.
Old 03-22-2008, 11:52 PM
TurboSevenThree TurboSevenThree is offline
I miss the 90's. =[
It is trying to tell you the battery isn't getting enough voltage. Be it the alternator or a fried battery or corrosion, just like he said .
Most likely the alternator though, since that is technically controlled by your foot on the gas or brake.
Old 03-23-2008, 12:35 AM
66Bronco 66Bronco is offline
Lightbulb
Don't get too concerned about the alternator just yet. Pop the hood and check the connection on the top back of the alternator. It may be hard to see as there is a heater hose that routes right over the top of it. Check that wire, because the heater hose itself will actually occasionally knock the wire loose and make the light flicker or stay on, depending on how loose the connection is. This happened on my '95, and when you compare the ten minutes and 3" strip of electrical tape I used to solve the problem to the $250 price tag on a new alternator, what have you got to lose?
Old 03-23-2008, 12:45 AM
I miss the 90's. =[
That is a good point. I was just suggesting it be something alternator related lol, which that type of thing would be included under. Great tip
Old 03-23-2008, 06:38 AM
Hey, Thanks everbody. You guys are one of the fastest responing groups That I subscribe to. Thanks again !!
Rob
Old 03-23-2008, 10:47 AM
scotty2280 scotty2280 is offline
my alt just died on friday in the bar parking lot (lucky) and i had a heck of a time getting one in stock of all 8 or 9 places i called they couldent get on tell the next day why dont they stock these? and ask you if its a 110 volt or a 140 volt mine was the 110
Old 03-23-2008, 05:52 PM
Seems like all the wires are intact. And the Alt. looks easy enough to replace. But how do you get that big fat wire off the back of it?? And whats the procedure to loosen the belt. I guess you can tell, I dont have a manual yet. How can I tell if its 110 or 140 volt??
Thanks, Rob
Old 03-23-2008, 06:17 PM
i think the 140 is for the ambulance models
Old 03-23-2008, 06:38 PM
d7rxr d7rxr is offline
110AMP.....most likely, very few snow plow preps came with 140 but mostly cab/chassis for the builders (ambulance, wreckers, etc.)
