A/C question: Recharge or repair? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-13-2013, 01:53 PM Thread Starter
I have a 2000 7.3 Excursion, and I live in Phoenix. The A/C is blowing cool air, but it seems to take a long time to get that way, and it doesnt get as cool as I'd like. It always seems like its just a little too warm in the truck.
So, I bought a 18 oz can of 134a+ with a gauge on it, found the low-side port and hooked it up. With the a/c running in the cab, pressure reads ~100psi (should be between 45 and 55 psi with the outside temp being ~100*)
So, I didnt add any refrigerant, and I'm curious: Is there something else causing my AC to be on the weak side? Or am I not doing something right?
greater_than_five is offline
post #2 of 5 Old 06-13-2013, 02:04 PM
Quoted: 17 Post(s)
What's the interior temp?
2000 Ford Excursion Limited 4x4 Diesel
2007 Jeep Wrangler unlimited on 1 tons & with 41.5" Pitbull Rockers
TBJK is offline
post #3 of 5 Old 06-13-2013, 02:10 PM Thread Starter
Do you mean What i the temp in the cab, when I hook up the can to the low-side port? The a/c hadnt been running for very long at that point. Probably pretty close to 110-120* as the truck had been sitting outside.
Or what is the temp after I've been running the a/c for a while?
post #4 of 5 Old 06-13-2013, 03:13 PM
ThomasvillePavers's Avatar
There are many factors for high pressure and low temp, could be a clogged or dirty condenser (the little radiator in front of your intercooler and actual radiator) could even be a failing clutch fan not pulling enough air through. It would greatly benefit you if you can hookup to both high and low side with gauges to go further here with diag.
-Brad
00' F350 CC DRW still pushing well past 300K: 6637, GTP38R, 5.6k mod on turn dial, superchips, trans command, Torque pro on Galxy S2 for PID monitor, OD lock, 4" straight pipe, condensor cooler w/electric fan, watersprayed intercooler, 08' taillights, 05' headlights, BD valve body kit, all door locks foiled, full LED exterior light kit, and the list is still growing.
ThomasvillePavers is offline
post #5 of 5 Old 06-13-2013, 04:31 PM
Quoted: 17 Post(s)
As he said there are many factors, condenser condition, evap core dirty, evap fan blades dirty. You need to have optimal conditions inside the cab to really go by gauges anyways. Get the cab to a normal temp then check pressures
TBJK is offline
