  #11 (permalink)
Old 03-24-2008, 02:21 PM
01clj 01clj is offline
My father in law put some of the trans tune in his 90's cavalier when he thought the tranny was shot figured he had nothing to loose. It was not shifting into 3rd or overdrive and would shake at idle with car in drive. It fixed it the first time he drove it after he added it and he drove that car for another 20,000 miles. Made me a believer in the power of Seafoam additives.
  #12 (permalink)
Old 03-24-2008, 06:42 PM
00Turbo444 00Turbo444 is offline
Send a message via AIM to 00Turbo444
ive yet to use it in my truck but we use it in our antique tractors cleans everything right out nice and smokey
  #13 (permalink)
Old 03-25-2008, 09:43 AM
SyN SyN is offline
Got Torque!
Sea Foam is a good product. I also use this product to clean the inside of the 7.3 and Transmission---> Auto-RX.com
  #14 (permalink)
Old 03-25-2008, 10:44 AM
CSIPSD CSIPSD is offline
...sticky injectors...LOL ok...
  #15 (permalink)
Old 03-25-2008, 11:03 AM
HVAC SuperTech HVAC SuperTech is offline
Input Shaft Twister
hmmmmm....Gonna have to try it out before I go out of town in my PSD tommorow. It did well in my Mustang and my F150. I love how so many people do the seafoam vids on Streetfire and you tube and such. hehehe...
  #16 (permalink)
Old 03-25-2008, 11:07 AM
GoldieStroker944 GoldieStroker944 is offline
well i am due for an oil change and fuel filter change so i will go and get some and see how it does i would really like to have a nice clean running engine
  #17 (permalink)
Old 03-25-2008, 11:50 AM
smuesse smuesse is offline
A guy came in our shop and bought some Sea-Foam. He said he was going to dump it in his oil before he changed the oil on is Stang. I am planning to change to Rotella 5w/40 Synthetic at my next oil change. What do you guys thing about dumping a can of Sea Foam in my engine about 100 miles before the oil chage?
  #18 (permalink)
Old 03-25-2008, 11:55 AM
sflem849 sflem849 is offline
I think I have seen oil change specific products for this purpose. I have never used Seafoam in oil, only in fuel.
  #19 (permalink)
Old 03-25-2008, 11:58 AM
Check this out:
Sea Foam
  #20 (permalink)
Old 03-25-2008, 12:04 PM
How to Use SEA FOAM MOTOR TREATMENT
In Tune-Up of Diesel Engines
Fill primary fuel filter with SEA FOAM. Be sure filter is fully primed to prevent air locks. This will clean injectors quickly.
Use 1 pint of SEA FOAM to every 25 gallons of diesel fuel to add lubricity, clean fuel lines, injector pump and remove moisture.
Use 1 pint of SEA FOAM to every 4 gallons of oil to clean rings and other engine parts internally. For best results, use SEA FOAM for 1 hour before oil change. Results in cleaner engines and longer oil change intervals.
Go ahead and use it in the oil!
I have always used the NAPA oil change cleaner stuff, but I might as well use Seafoam now!!!
