Old 03-21-2008, 06:49 PM
marc9441 marc9441 is offline
BIG oil leak on 02 NEED HELP please
drove 250 miles got back into town stopped and oil was pouring out underneath. checked oil level none registered!!!!!! no warnings no sounds no check engine no limp mode . i didnt screw her up did i? thought they had a low oil shut off ? oil is coming from back side dripping down bellhousing bottom of truck is coated!!! what to do ???
Old 03-21-2008, 06:59 PM
Old 03-21-2008, 07:27 PM
lamarmathis lamarmathis is offline
start by looking in the valley on top,it is probably the hpop orings leaking,the engine shouldnt be hurt they will shut off when the resevoir for the hpop runs dry.good luck to u
Old 03-21-2008, 08:15 PM
gonna look tomm thank you
Old 03-21-2008, 08:38 PM
Diesel Monkey Diesel Monkey is offline
Fairly sure that injectors will no longer operate before oil pressure to the lower end is completely out. Can someone confirm this?
I had a HP hose go out near La Pine Oregon. Oil everywhere. Napa store in La Pine made me a new one. Took a little while to get the air out of the high pressure oil in the heads.
Old 03-21-2008, 09:08 PM
planeoldguy planeoldguy is offline
Mine did exactly the same thing, My HPOP was smoked................
Old 03-22-2008, 04:46 AM
Southpaw Southpaw is offline
1/20/2013
our injectors use high pressure oil to operate, if you lose your oil pressure, your injectors will stop firing, thus shutting the motor down. This happened to me on my old 97. Drain plug was stripped, and fell out 11 miles after an oil change!! Truck shut off, and I got out in time to watch the last 5-6 quarts of oil drian out the hole. No damage at all done to the truck. Except for the stripped oil plug.
you're fina as far as that goes...As far as the oil leak goes, trace the oil to the source. The valley is a great place to look for oil. Could be the HPOP o-rings or pedestal o-rings. Check it out and let us know what you find. I had a leak on my 02 that I chased for 2 months, it can be aggrivating, but you'll get it.
Good Luck
later
Old 03-22-2008, 04:47 AM
1/20/2013
Is the truck running?
Old 03-22-2008, 06:00 AM
yes truck is running ,got it to the house and added oil gonna start looking this morning. thank you
Old 03-22-2008, 06:11 AM
sea71 sea71 is offline
My 02 did it also. It was one of my hpop o rings. Leaked like it was coming out of a faucet. I got the three o ring kit from Ford and chaged them myself. Here is a link to another useful thread for ya. Good Luck !
99-03 7.3 oil leak diagnosis
