Turbo Chirp? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 06-12-2013, 04:01 PM Thread Starter
Turbo Chirp?
Hey folks,
I notice that when towing our fifth wheel (11K lbs)up extended steep grades and the EGT's begin to climb ~1000-1100* with the boost somewhere between 10-12psi I sometimes hear what I can best describe as a chirping sound which seems to be coming from the turbo area or the intake. The truck runs fine, doesn't seem to lack power and all gauges hold steady, nothing fluctuates. If I let up a bit on the throttle it'll go away or if the EGT's drop down to say 900* I don't seem to hear it. Towing on smaller grades, 4-5% where my EGT's stay lower I just never hear it. All my turbo boots and connections seem tight, no leaks that I could find. I had a DP-Tuner previously and I heard it with those tunes too. Haven't done much pulling with it in stock mode but I guess that will be next. Never happens when not towing or towing on anything but the steepest grades.
Any ideas? Anyone heard this before?
Thanks and regards,
2000 F350 7.3 4X4 SRW, SC, LB, VDO Gauges, JWVB, PHP Hydra, Tru-Cool Max, KYB Monomax, BTM, BD Brakeloc, S&B CAI, zoodad, WW, Firestone Airbags
cpfullback is offline
post #2 of 20 Old 06-13-2013, 06:34 AM Thread Starter
Okay, well, I did some more reading last night and it seems I have turbo surge when towing up big hills. Someone had a you tube posted of his surge and it fit my symptoms. OK, next question. I'm sure someone has had this and fixed it. Did changing out the compressor wheel clear it up and if so which manufacturer did you use (Banks, wicked wheel, etc)?
Thank you
post #3 of 20 Old 06-13-2013, 09:42 AM
blue99stroker's Avatar
Quoted: 262 Post(s)
get the wicked wheel 2!
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 20 Old 06-13-2013, 10:07 AM
atgreene's Avatar
you can do WW or a ported compressor housing, both will help with surge, i think the housing, even though it is 425 instead of the WW being around 200, is well worth the extra money because it sounds awesome!
youtube ats ported housings
atgreene is offline
post #5 of 20 Old 06-13-2013, 10:46 AM Thread Starter
I'm in California so I don't think the ported housing will work for me. SMOG police. I've talked to a couple of shops here locally and the one guy who knew exactly what I was describing indicated that so long as I'm not producing a lot of boost (which I don't) and I'm happy with the power my truck produces that the surge is more of an annoyance than anything. He said he had no problem taking my money but if I could live with the surge sound once in a blue moon that it really wouldn't hurt anything. Does this sound right to you guys?
post #6 of 20 Old 06-13-2013, 12:10 PM
Quoted: 262 Post(s)
surge is far more than a simple annoyance!
it is very damaging to a turbo.
go with the ww2 from dieselsite. a ported housing cures surge but thats all it does. a ww2 actually is a perfomance mod. and its half the price of a ported housing.
most people see a increase in boost, lower egts, and lower drive pressures.
riffraff sells a new billet wheel and so does bd so theirs a few to choose from.
post #7 of 20 Old 06-13-2013, 01:43 PM Thread Starter
I contacted a local diesel mechanic who has installed a ton of these. I set up an appointment with him to install one on mine. He uses the billet compressor wheel from BD Power for his installs. That should do right?
Regards
post #8 of 20 Old 06-13-2013, 04:29 PM
Quoted: 262 Post(s)
ive heard good things about bd's new billet wheel.
you will be happy with the results
just a thought, how much is he charging? cause you can buy it for 185 bucks and its easy to install.
post #9 of 20 Old 06-13-2013, 06:28 PM Thread Starter
I seriously considered doing it myself but I didn't feel too comfortable getting in there with an impact wrench and screwing something up. Besides, I just finished doing a BD Brakeloc install and my back is screaming at me not to contort my back trying to get to that turbo for a while :-)
When the mechanic said it would be 1.5 hr. labor (~150 bucks) I said sure. My wallet doesn't like it but my back will.
post #10 of 20 Old 06-13-2013, 10:07 PM
Quoted: 262 Post(s)
well how do you know he wont use an impact
tons of people have used impacts to change the compressor wheels, myself included. although taking the turbo out isnt that bad.
but in the end your truck....and your back will thank you
