99 f450 6spd conversion - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-12-2013, 10:33 AM Thread Starter
I have a 99 f450 aluminum body dump truck with 135000 miles on it. Has big rearend gear. Had the automatic rebuuilt about year and a half ago. hardened input shaft,billet torque convertor,hd clutches. This thing does 80 at redline. I want to convert it to a six speed. So where do I start? I need pedal assembly,trans,etc. anyone able to break this down and maybe know where to locate some of the parts? any help would be great. thanks
chopperchip is offline
post #2 of 7 Old 06-12-2013, 11:12 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Your gonna want a parts truck for sure otherwise your gonna be nickel and dimeing your wallet left and right
Heres a sticky
Auto to Manual Converstion
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 7 Old 06-12-2013, 01:58 PM
Joel's Avatar
Quoted: 10 Post(s)
Just curious, what does the "redlines at 80" have to do with a tranny swap?
Is 80mph not fast enough for a dump truck?
The overdrive gear ratio is very similar if not the same on the two trannys so top speed will not be affected.
But if you want to have a 6speed for other reasons, go for it
Good luck with the swap
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 7 Old 06-12-2013, 02:05 PM Thread Starter
let me clarify this, I'm on the highway a lot, from 68-80 i'm pushing redline. now i've been in some 450's with the same rear gear and they are not revving that high all the time. even 50-60 is high rev. not only that, but I pull a cat 289c with a mulcher on a heavy trailer, would like the option of up and down shifting
post #5 of 7 Old 06-12-2013, 02:13 PM
Joel's Avatar
Quoted: 10 Post(s)
I totally agree that the 6 speed is a better fit for an F-450, especially one hauling weight.
But the final drive ratio of the two transmissions in question is the same. If you want to change that you will to change ring and pinion in the diff as well.
Joel is offline
post #6 of 7 Old 06-12-2013, 03:04 PM Thread Starter
anyone know where to view the specs between the 2 transmissions?
post #7 of 7 Old 06-12-2013, 04:23 PM
700xxmaniac's Avatar
6 speed is slower I'll top out at about 78 lol od on the six is .73 on the 4r100 it's .71 I believe
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
