Looking at a truck - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-12-2013, 08:33 AM Thread Starter
Looking at a truck
I'm going with a buddy to check out a 99 7.3 reg cab long box with a plow for him
Truck has 165000 some rust but overall clean truck
Anything to b worried about with the plow ?
Anything special to look at and check ?
Anything I should bring with me?
Thanks guys
2002 F-350 7.3 ex-cab short bed Beans 6 Pos
6 inch lift, 35,s, 4 Inch Turbo Back, 6637 intake
Foil delete, 05 harley front end, 08 Tailights
Tinted cab lights, and this and that and this
Z-STROKE is offline
post #2 of 10 Old 06-12-2013, 10:16 AM
UNDERCOVER_73's Avatar
Just common sense, if your buying it to get something hassle free and pay tol dollar,b our your looking to save a buck.
Check for cod start issues = glow plugs
When you go to look at it request that he didn't start it on the day you go and check it out, if he has a problem then theres somthing hes.hiding.
Check for blow by or hiccups & missing,
Look under the dash for any unnecessary wires or rigged up looms
Go thru all the gears manually.
Check under neath for any oil leaks on the front axle
Sent from my LG-MS770
-06 F250 SCSB 6.0 191k
TSD Super Panty Dropper
190/100s
Gt4294 Turbo
5" Exhaust
Airaid intake
Studded and Deleted.
50" Led Light Bar
4" lift 37x14s
-04 Crown Vic P71 interceptor 160k
UNDERCOVER_73 is offline
post #3 of 10 Old 06-12-2013, 12:30 PM Thread Starter
How can I tell an early 99 ?
Z-STROKE is offline
post #4 of 10 Old 06-12-2013, 12:31 PM Thread Starter
And would u pass on an early 99 for a late model ?
Thanks
Zach
Z-STROKE is offline
post #5 of 10 Old 06-12-2013, 02:54 PM
look in the door and check the dates
190/100s
Gt4294 Turbo
5" Exhaust
Airaid intake
50" Led Light Bar
4" lift 37x14s
post #6 of 10 Old 06-12-2013, 03:20 PM Thread Starter
So if it is 98 it is early 99 .. And then any 99 is a late 99 ?
Z-STROKE is offline
post #7 of 10 Old 06-12-2013, 04:01 PM
sealeveloc's Avatar
Quoted: 19 Post(s)
Ive heard to check the oil pans on the 7.3's they rust out and you have to pull the motor or at least jack it up off the mounts and let the oil run out for days to get a good seal on the new pan
good luck!
Byron
O6 350 XL
The usual I wanna go fast mods,
maybe a lil more,
maybe a lil less
sealeveloc is offline
post #8 of 10 Old 06-12-2013, 08:54 PM Thread Starter
Thnks for the tip
Anything else ? Guys hope this things in good shape he's been looking for a 7.3 for a while
Z-STROKE is offline
post #9 of 10 Old 06-13-2013, 07:00 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Front and rear pinion seals. Especially the front almost every Dana 50 I've seen (cold weather, I'm from Canada) has a leaking front pinion seal
schlutzer is offline
post #10 of 10 Old 06-13-2013, 11:10 AM
atgreene's Avatar
watch powerstrokehelp.coms videos on buying a used truck
atgreene is offline
