The Nitto Dura Grappler is based on the award winning technology of the Nitto Terra Grappler. The Dura Grappler is specifically designed as a multi-purpose towing tire. If you are carrying heavy loads at the construction site or towing your bikes and boats on the weekends, the Dura Grappler provides extended mileage and tread life under these conditions.
The Dure Grappler maximizes tread life with these unique features:
- Dura-Belt 3 steel belt technology, that reinforces and stabilizes the tire's internal construction
- Deep tread grooves for longer lasting tread life
- Wider contact patch for more even tread wear
- Rigid, multi-rib tread blocks. The rib's continuous design strengthens the tread blocks to reduce irregular wear
The Dura Grappler is also one of the few Tire Pressure Monitoring System-compatible tires on the market with an 80PSI max inflation pressure (available in most sizes).
The Dura Grappler is available in sizes for Ford Super Duties.
Click here for Nitto Dura Grappler sizes.
Nitto Dura Grappler
Nitto Dura Grappler
This PostRelease(tm) is part of an advertiser-supported program that sponsors Ford Powerstroke. This program delivers relevant news and announcements as posts within the Ford Powerstroke forum.
