Trans filter for ZF6 ? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-12-2013, 03:48 AM Thread Starter
Colin7.3's Avatar
Is there a way to put a trans filter on a ZF6 ? Maybe in one of the lines going to the factory cooler?
I'm from the heavy duty world and ours have filters on them. I'd feel a lot better if I could put one in it.
Any ideas?
I'd perer to use a Baldwin filter also
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #2 of 8 Old 06-12-2013, 02:30 PM
Quoted: 17 Post(s)
Feedback Score: 3 reviews
here you go.
http://www.dieselsite.com/1999-20037...tersystem.aspx
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 8 Old 06-13-2013, 03:42 AM Thread Starter
Colin7.3's Avatar
Is there anything special about the filter base or is just a normal Baldwin base?
I have that filter here at my house I bought. Now if the filter has the bypass is built in. It'd be a normal base and I can fab lines to work no problem ( I work at a john deere dealership and can have hi pressure lines made for cheap )
I can build the bracket to Mount it to frame myself also.
Any ideas?
Colin7.3 is offline
post #4 of 8 Old 06-13-2013, 05:50 AM
Quoted: 17 Post(s)
I think the base has the bypass built in and you can use baldwin filters
post #5 of 8 Old 06-13-2013, 08:28 AM
timmyboy76's Avatar
i cut my trans line, coming from the radiator, then to filter, then back to trans..
Name:	trans filt 1.jpg
ID:	124234   Click image for larger version
Name:	trans filt 2.jpg
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 8 Old 06-13-2013, 08:30 AM
timmyboy76's Avatar
here's the plumbing...
Name:	trans line 2.jpg
ID:	124250   Click image for larger version
Name:	trans line 3.jpg
ID:	124258   Click image for larger version
Name:	trans lines 1.jpg
post #7 of 8 Old 06-13-2013, 09:31 AM Thread Starter
Colin7.3's Avatar
Any leaks with just using the rubber line and clamps?
That's a lot cheaper than the pressure hose id use. Which line is the feed line to the cooler from the trans ? I wanna hook it up how diesel site has it
Colin7.3 is offline
post #8 of 8 Old 06-18-2013, 06:46 AM
timmyboy76's Avatar
no leaks. Atleast 60k on setup
