Swap 4.10 for 3.73 gears? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-11-2013, 01:03 PM Thread Starter
I have a 99 model 4x4 dually with 4.10 gears used to tow our travel trailer. Wife wants to take the truck on a 4000 mile trip this summer. Local guy has a set of front and rear low mileage 3.73 gears for sale.
Would it be worth the time and money to swap the gears for better MPG and lower RPM on highway? Do the 3.73 swap out easy into 4.10 housing?
JB4XX is offline
post #2 of 15 Old 06-11-2013, 04:15 PM
Joel's Avatar
Quoted: 10 Post(s)
The front is a direct swap.
I don't think the rears will though as the local guys gears are probably from a SRW truck and the dually uses a different rear end.
Buy bigger tires
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 15 Old 06-11-2013, 04:32 PM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
your rear end is a Dana 80 the SRW trucks use a sterling 10.5 so the rear gears as stated above are not interchangeable
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 15 Old 06-16-2013, 04:37 PM
Unless you're doing this yourself, most of the cost is in labor. Don't cheap out with used gears. Also, if you're doing it for the fuel cost, youre going to have to drive a lot more than 4k miles to make up for the swap costs.
That being said, I'm swapping my 4.10's to 3.73's next time I have the rear apart. I just want the lower cruising rpm's mostly.
'03 7.3 Lariat. 320k and counting
8secondride is offline
post #5 of 15 Old 06-16-2013, 06:59 PM
Quoted: 12 Post(s)
Feedback Score: 3 reviews
If all you use it for is towing, then don't swap. Maybe a taller tire.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #6 of 15 Old 06-16-2013, 07:15 PM
If your pulling near maximum weight I would stick with the 4:10's sure its a ***** on the freeway but if you drive 60-65 it isnt bad. If your at max weight and going up any type of decent grade you will be thankful for any shorter gear you can get.
99.5 F350 DRW CC 4x2 53k on the clock 7.3 6637 intake mod. Hand made 4" exhaust. 4.10 gear.
92 Mustang lx 362ci N/A 830hp. Ultra street & X275 car
calypso50kid is offline
post #7 of 15 Old 06-16-2013, 08:06 PM
Macon's Avatar
I wouldn't change them. Unless you're keeping stock tire size, 4.10 is what everyone else wants. 35's will drop RPM's, bringing it to ~stock engine speeds. Since it's a dually, narrow tires are required, so you mileage shouldn't be affect much by the height change. I would love to say it's better, but a stuck hub fudged my numbers.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #8 of 15 Old 06-16-2013, 09:59 PM
Joel's Avatar
Quoted: 10 Post(s)
255/85-16 is a tire match made in heaven for a dually if you're still running stock rims
Joel is offline
post #9 of 15 Old 06-17-2013, 05:05 PM
Quoted: 14 Post(s)
....'cept 255's only seem to be available on a mud/offroad tread. Mine has 255's and I was going to stick with them but no one seems to have that size on a street/mild offroad tread anymore. Evidently they have been discontinued.
ttyR2 is offline
post #10 of 15 Old 06-18-2013, 10:30 PM
Joel's Avatar
Quoted: 10 Post(s)
I know what you mean.
The only tire I know of that I would consider is the Toyo M55
I like that tire
Joel is offline
