What gives? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-11-2013, 01:22 AM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
What gives?
I have two trucks ( one for parts)
DD is an E99
Parts is a 2000, both 4x4
I though the E99 had different lug nut thread pitch? On a whim I decided to try swapping a lug and they fit...
Which of these trucks is the bastard?
schlutzer is offline
post #2 of 10 Old 06-11-2013, 03:46 AM
goats's Avatar
Quoted: 2 Post(s)
I beleive it changed in 05
goats is offline
post #3 of 10 Old 06-11-2013, 06:36 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
If the hubs have been replaced they could have used a hub with a different than original thread.
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #4 of 10 Old 06-11-2013, 11:05 AM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
Not likely. My E99 is very low mileage
post #5 of 10 Old 06-11-2013, 12:30 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Ill tell you whats a bastard is having a truck with different thread pitch between the front and back
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 10 Old 06-11-2013, 05:46 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
I got excited, then sad.
I went to put my factory hub caps on my aftermarket rims. Used the lugs from my parts truck and everything is going great, an they look great.
Then I get to the last rim and notice something.
Factory rims are hub centric, with flat lugs.
My aftermarket rims are lug centric, with conical seat lugs.
Therefore my idea to use the stock lugs/ centre caps from the parts truck is totally bunk. Damn.
post #7 of 10 Old 06-12-2013, 04:45 PM
700xxmaniac's Avatar
Look and see of the rims are snug on the hub my rims have pitched lugs but the fit sug like on the hub too just like stock rims
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #8 of 10 Old 06-12-2013, 06:40 PM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
They aren't
post #9 of 10 Old 06-18-2013, 04:34 AM
dieselcrawler's Avatar
Quoted: 23 Post(s)
E'99 will have unit berrings and rotors with slightly diffrent wheel mounting surface depth when compaired to later model trks. Later bearings and rotors are also cheaper. I swapped my E'99 to later berrings and rotors so all 3 trks would use the same spare I keep on the shelf in the shop.
Lug nuts changed thread pitch around '02 IIRC. Went from early coarse thread to finer thread. Wheel offset changed with the coil spring front end in '05.
Greg
'99 E350 DRW Stahl 11' util box van, 7.3 PSD, stock. 138k SOLD
'00 F350 extcab, 9' utility bed, dually 228k
E'99 F250 extcab, S/Bed 211k. Sidelined due to motor issues.
'00 Excursion Limited, 7.3PSD 294k
'84 Chevy K-30, 6.2L TD, woods/trail beater. 141k
Semper Paratus
dieselcrawler is offline
post #10 of 10 Old 06-18-2013, 11:15 AM Thread Starter
schlutzer's Avatar
Quoted: 18 Post(s)
Okay thanks. I was under the impression that the E99 trucks also had a different thread pitch.
Actually I'm sure some do, I've seen two different wheel bearings on websites for E99
