How to get fuel out of oil? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-10-2013, 05:21 PM Thread Starter
Colin7.3's Avatar
When I had my injector o ring split. It had got fuel in my oil. Since then I changed my oil and let it drain for awhile. But after I refilled the crank case. And running for awhile. I now notice that when I pull my dipstick it has fuel on it with the oil.
Now is there a good way to remove the oil? Like an additive to absorb it or anything like that?
Or should I just drain it again, and the HPOP resivoir and rails and just go from there?
Thouhts and ideas? Thank you!
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #2 of 5 Old 06-10-2013, 05:24 PM
Wannabitawerm's Avatar
If the problem is fixed, there will be residual in the hpop. I would drain, refill and change the filter one more time. The hpop holds about 3 quarts.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #3 of 5 Old 06-10-2013, 05:29 PM Thread Starter
Colin7.3's Avatar
I ended putting in a new o ring set on said injector.
I was thinking along those lines of getting all the oil out and full refill with all new oil even in the HPOP
Colin7.3 is offline
post #4 of 5 Old 06-10-2013, 06:21 PM
schlutzer's Avatar
Quoted: 18 Post(s)
I would probably opent he HPOP reservoir and suck out the oil from there too... get as much as you can.
schlutzer is offline
post #5 of 5 Old 06-11-2013, 02:44 AM Thread Starter
Colin7.3's Avatar
I was gonna do that and also open the rails up in the heads.
Colin7.3 is offline
