Questions about normal operation? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-10-2013, 03:07 PM Thread Starter
I just got my Edge Insight CTS not long ago, and have recently begun to check all that it can monitor.
First couple questions are:
How accurate are the truck's gauges? As in the Edge insight reads off the truck, but says my transmission will get up to ~180*F (cruising 65 down highway, 82* ambient temp)
My normals sound a little high, so what do these indicate to you?
Boost: MAXED out around 16 (boosted launch hits 16 or so in 3rd gear)
Trans Temp: 180* (unloaded, truck only as previously mentioned)
Engine Oil Temp: 205* (same situation)
ICP: 2850psi
IPR%: 37%
0-60 time: 14.6s (boosted launch)
1/4 mile: 19.0s (boosted launch)
I have not gotten an EGT probe yet, should be here tomorrow.
Known Issues: I have got a SMALL oil leak (1-2 drips every time I stop). I have cleaned the top/valley of the engine, and it has not re-oiled, so it must be on the rear of the motor.. I'm guessing turbo pedestal, but haven't tracked it down.
Anything I should be looking for, the ICP/IPR seem good, but I think the EOT, and Trans are getting a little warm. And I don't think a stock truck is quite this slow? I would like input from you, before I go upgrading anything I want stock to be right.
Truck is:
2002 CCLB - 248,000 miles.
No felt slip in the trans/shifting
~2000 miles on oil (black)
265/75R16 Firestone tires
All stock and original as far as I know/can tell.
Please help, I just need to get this sorted out before it gets expensive.
BigDaddyJob is offline
post #2 of 3 Old 06-10-2013, 05:04 PM
What is ipr at idle? Should be no lower than 14 psi
Sent from AutoGuide.com App
Jduff27 is offline
post #3 of 3 Old 06-10-2013, 07:14 PM Thread Starter
Honestly, I didn't make a note of it, I will check tomorrow morning before I head in to work. From reading/searching it seems like I am just a little higher than "normal" on oil temp and trans temp. That also assuming that the trucks sensors are accurate.
